radiator standoff panels
Bill Ramsey
Post by Bill Ramsey »
there are 2 (for this purpose, I know there is more variations) different core supports, one where the radiator mounts flat to the core support, and one that has standoff brackets spot welded to the core support. This extends the radiator out and at a slight angle. These brackets are usually found on Highboys and F350's. I need those brackets, either cut off a trashed core support or a complete core support that has them. I prefer just the brackets though. I know its a long shot, but help me out. thanks,
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
Re: radiator standoff panels
"Bill Ramsey"]there are 2 (for this purpose, I know there is more variations) different core supports, one where the radiator mounts flat to the core support, and one that has standoff brackets spot welded to the core support. This extends the radiator out and at a slight angle. These brackets are usually found on Highboys and F350's. I need those brackets, either cut off a trashed core support or a complete core support that has them. I prefer just the brackets though. I know its a long shot, but help me out. thanks,
Bill the proper terminology here is called "SUPER COOLING RADIATOR SUPPORT" (will make it a lot...easier to find them if you use those words).
But...I doubt you will find them as the ones that are not rotted out are still in use and are as rare as hen's teeth.
I have some good pictures of it from my old F-350. :(
Bill Ramsey
I do not agree. They may be hard to find, but definately dont qualify as Hens Teeth. Im in SoCal, and parts are plentiful around here and I know where to look. Dents also had them, just gotta be patient and they will probably just fall into my lap.
If Someone here has them, even better.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
"Bill Ramsey"]I do not agree. They may be hard to find, but definately dont qualify as Hens Teeth. Im in SoCal, and parts are plentiful around here and I know where to look. Dents also had them, just gotta be patient and they will probably just fall into my lap.
So...you don't even know what the part is called but you know there's a bunch of them lying around in cali. :yt: :lol:
Good luck with your search bill.
In the meantime...let me bring you up to speed. :yes:
http://www.fordification.com/forum/view ... hp?t=35747
Bill Ramsey
Picked up a core support, highboy bumper brackets, and a pair of Ford mirrors for $100, today.
Am I up to speed yet?
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
"Bill Ramsey"]
IMG_20171214_41363.jpgPicked up a core support, highboy bumper brackets, and a pair of Ford mirrors for $100, today.
Oops...I stand corrected. Looks like they are a lot more plentiful out there on the West Coast than they are over here in the rust belt.
I hope you enjoy your new radiator standoffs. :hi:
hdman90
Post by hdman90 »
Wow! You found your two missing items! Stand-offs and bumper brackets! Score!
That was fast! :thup:
