Need C9TA-3590-E pitman arm!
WTB pitman arm casting #C9TA-3590-E..........getting ready to replace drag link and ends and want to replace the one I have with the correct one while I have everything apart!
1997 Honda CBR 900RR
Re: Need C9TA-3590-E pitman arm!
I have a pitman arm but not that exact number. I think its the same but older.
OK after some searching the Pitman Arm #C9TA-3590-E is for Power Steering, The one I have #C7TA-3590-N is for Manual Steering. I found that by looking here: https://fordification.com/partnos/steering-column.htm
I just appreciate you taking a look - these things must be like hens teeth!......
