Project frankenweenie
mlheppl
Re: Project frankenweenie
Post by mlheppl »
That would be awesome. Thanks. btw, where in Utah are you if you don't mind me asking. Looking at your pics, I'm thinking south east Utah, somewhere nearby Lake Powell as a guess.
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
frankensteined_67
Post by frankensteined_67 »
well im in salt lake now. but the first four pic's are in St. George. Thats where i picked up Frank in 1996. it was my third/fourth high school truck.
one_am
Post by one_am »
frankensteined_67 wrote:well got the bed back off and had to put the cab and front clip on, so i have some weight on the frame when i make the new rad. arms finally. just dont know if it will come out of the garage now even with the smaller tires on it.
lookin good. I like a nice 4x4. Your not kiddin, you might have to pull your front springs out to the the truck out of the garage
:doh: Hood latch
69 F100 custom cab swb 460 c6 9 code rear axle (project).
bjde0b wrote:I jacked a sway bar off...
frankensteined_67
haha ya with the 31" and on the rollers it is 1" lower then the door opening. i will have to push the door up about 3" too get it out of there. my dad says it remindes him of that guy that built a motor in his basement and then could not get it out. I dont have a update on the truck i have been working on my Toyota truck (aka taco). the story on that is i woke up and it would not start. so i thought fuel pump. went and got a pump $146 later put it in and still nothing. checked spark got spark. so i went to the junk yard and stole a fuel pump relay cus it was like $86. but i found a passenger side 67 door panel uncut. i found the drivers side on last week. so that was ok. got home put the relay in and nothing. read some more on the issue and found that the maf sensor could do this. so called around and it was about $800 new so i went and got one from the almighty junk yard and pick up one for $45. and walla it runs. then i was putting every thing back to together and found out i broke the fuel hard line that is on the fuel pump housing. so back to the junk yard in the morning. O and i had it scheduled to have a new cat put on it labor free. why cant it be easy. and im looking for a job too. this is getting ridicules.
frankensteined_67
cant believe it's been five years sense i wrapped up frank.
[URL=http://s638.photobucket.com/user/f ... .jpg[/img][/url]
pulled the cover back some. and man is it dirty.
also i found this nice looking bed.
going to put these on the stands i made. once i can find some bolts to put on them.
frankensteined_67
No work on the ford but I did find I new use for a 22re
frankensteined_67
built this. its a life saver. car rotisserie.
Now I just need to get that new bed mounted on it
