crew cab f-350/f-600
dieselbronco
Post by dieselbronco »
had the idea to take apart my truck to build my dream truck i have had my 67 f-350 crew cab for a few years now and got bored of it so i found a 71 f-600 so here it is hopefully its nice this weekend so i can get some more done
forrestbump
Re: crew cab f-350/f-600
Post by forrestbump »
That's a Great Bump!! What a monster... and unique... Love what you've done.
Larry
70 ranger
Post by 70 ranger »
That looks great keep us posted!
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
dolinick
Post by dolinick »
oh man! that's what I want to do with my F750. I just need to get my hands on a crew cab cab. do you think it would be possible to put F100 fenders and grill on a F600? What kind of bed do you plan on using?
2003 7.3L F250
1968 F500 Utility Truck
BlueOvalDave
Post by BlueOvalDave »
any more progress? Suspense is killing us!
dieselbronco
Working on it picked up some dually fenders for the bed now I have to try to get them to look good hopefully I will be driving it by the end of the weekend
Then I'm working on getting a diesel for it
dieselbronco
well i got the cab mounted had to make all new cab mounts on the front i used the stock rear brackets off my 350 frame
i got the pedal assembly and column in too had to cut out a peice of the dash from the 600 and weld it into the crew cab
and had to cut a new hole for the column and clutch linkage
dieselbronco
the bed is just sitting on there for now im gonna slide the axle back to center it in the wheel well and still deciding what to do with the dually fenders open to any ideas on them
BlueOvalDave
wow, I kind of like it the way it sits now without the fender bubbles.
Except theres nothing to keep stuff from getting slung off the outside tires.
But shes definately a looker :wink:
FordTruck
Post by FordTruck »
dieselbronco wrote:the bed is just sitting on there for now im gonna slide the axle back to center it in the wheel well and still deciding what to do with the dually fenders open to any ideas on them
Could you use some front fenders for the duals?
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
dieselbronco
I think I would need 4 600 fenders then I could
forrestbump
:pop: :pop: Can't wait to see more pictures!
BlueOvalDave wrote:wow, I kind of like it the way it sits now without the fender bubbles.
Have y'all considered converting to 4X4? Not tryin' to make you're head swim... just sayin'...
Larry
averagef250
Post by averagef250 »
FordTruck wrote:Could you use some front fenders for the duals?
I like that idea, I think it could look really cool done right. A lot of work though.
dieselbronco
Thought about 4 wheel but no need more for towing and I have no self control if I make it 4 week I will beat the Hell out of it
And if I could find the front fenders I would do it not afraid of the work I have a set of newer dually fenders I'm gonna trim up to fit for now.
And I am picking up my diesel donor truck tomorrow so should have that in this weekend
forrestbump
:pop: :pop: I'm lovin' your truck... can't wait for more updates.
Larry
