67- SWB, CV swap, 2007 3v 4.6/ 5 sp
Coupe5oh
Re: 67- SWB, CV swap, 2007 3v 4.6/ 5 sp
Post by Coupe5oh »
IN2FORD wrote:Got another question for ya...I was looking at the pics of the clutch master cylinder mounted to the pedal box. The side pic looks like the master cylinder sticks past the end of the mount. Does it? I would think the firewall would be in the way.
Barry
The master sticks out into the engine compartment far enough to attach the line to the slave. It's mounted like that in the mustang I pulled it from too.
Bigfreeb wrote:Did you like how the Exploder rear end worked out for you? I was wondering about the offset center making the driveline go off at an angle. I have a '02 crown vic rear and a Explorer rear still trying to decide how I want the wheels to set positive or negative. Also I see you posted the master/booster/valve from ebay but did it say it was for any particular vehicle combo? Very cool build you have done great work on this bump.
The engine is in stock crown Vic mounts, and sits about 1.5" offset to passenger side anyway. I don't know how much more the rear is offset but no issue that I know of.
The master/booster is for a 67-72 ford truck. Thanks!
-1993 Cobra #121, Black/ Grey leather
-1968 Mustang GT Fastback, Gulfstream Aqua
-1967 f100 pile of parts...
Coupe5oh
Post by Coupe5oh »
You can see it right below the reservoir protruding through the firewall (left of booster). It has a braided line going to the slave.
HomemadeTools
Post by HomemadeTools »
Ken here from BuildThreads, Inc.
Congrats and nice work Coupe5oh - this build thread was chosen as a Best Build Thread pick for this week. Image
What this means is that a bunch of guys who like to build stuff (cars, trucks, 4x4s, bikes, cabins, boats, planes, and garages) and have read a ton of build threads, thought that this build thread makes a valuable contribution to online DIY culture.
So, without further ado:
Congrats again and cheers! Image
Monkey-1
Post by Monkey-1 »
Killer build. I just read this whole thread from start to finish and am totally impressed. Love the stance and the color is spot on.
-Monkey-1
1985 F-150 Build Thread (CV Swap, 4.6, Frame-Off) https://www.ford-trucks.com/forums/1519 ... 4-6-a.html
1977 F-100 Flareside Build Thread (CV Swap, 4.6, Frame-Off) https://www.ford-trucks.com/forums/1545 ... hread.html
Studmonkeyracing.com
studmonkey@bellsouth.net
jcat5503
Post by jcat5503 »
How does the truck run? Does it have quite a bit of pep? I'm looking for a bumpside currently, and am cotemplating engine choices...
Coupe5oh
Post by Coupe5oh »
It's no slouch, I've added a set of the hotrod cams since its been finished. The motor is 340 hp stock I believe. I also just recently bought a used whipple HO setup for it... So should be tons of fun when I get it put on.
Cams make it sound way meaner than it is. :)
redmcode
Post by redmcode »
Great build, just finished it from the beginning to now........great work !!
hackster
Post by hackster »
Coupe5oh wrote:It's no slouch, I've added a set of the hotrod cams since its been finished. The motor is 340 hp stock I believe. I also just recently bought a used whipple HO setup for it... So should be tons of fun when I get it put on.
I still love this truck man, great work. Blower will be friggin awesome.
Sean
Coupe5oh
Post by Coupe5oh »
Thanks guys, blower is almost wrapped up. Appointment to get it tuned in a couple weeks. Excited to get it running again.
Monkey-1
Post by Monkey-1 »
Any updated pics of the engine?
-Monkey-1
Coupe5oh
Post by Coupe5oh »
Here it is mostly complete. I have it done now and will go to tuner Monday morning.
Coupe5oh
Post by Coupe5oh »
Monkey-1
Post by Monkey-1 »
Looks great. How does she run??
Also, noticed you swapped master cylinders. What prompted that? Performance or Clearance?
-Monkey-1
Coupe5oh
Post by Coupe5oh »
Thanks. I changed the master cylinder because it hit the throttle body after it was relocated. I've been telling everyone it's the best part of the whole install. Got rid of the clunky corvette style POS that I've hated since I built it.
Took it Monday and had it tuned. It made 457 hp and 430 tq at the wheels.
Monkey-1
Post by Monkey-1 »
Coupe5oh wrote:Thanks. I changed the master cylinder because it hit the throttle body after it was relocated. I've been telling everyone it's the best part of the whole install. Got rid of the clunky corvette style POS that I've hated since I built it.
Thats a good looking MC, do you have a part number?
I am interested in knowing what all has been done to the motor to reach those number? Is it still pretty streetable?
-Monkey-1
