68 F100 SBFS build; CV, T45, DOHC/M122, Cobra IRS
SATURN5
Post by SATURN5 »
Thought I'd start a build thread of my 68. Originally began some 8-9 years ago then "parked" as I bought a SVO and modded the heck out of it.
As I bought it in Little Rock, before driving it back to Ohio.
Had a 350 Olds and trans under the hood, with 75 power discs.
Once doing a teardown, put a MN12 IRS out back.
Considered putting a Aerostar IFS in, tacked in place and decided I hated it..
It had a sunroof cut in, and a bad windshield seal, which rotted the floors. I did some basic sheetmetal patches and attempted to put a Mustang sunroof in place of the junk aftermarket.
Once welded in, the flatness of the F100 roof was too much for the curve of the Mustang sunroof. Again, wasn't happy. About this time, I bought the SVO and the F100 was put outside and tarped.
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
SATURN5
Re: 68 F100 SBFS build CV, TR3650, DOHC
Post by SATURN5 »
The SVO, complete repaint, put in T tops. Built 2.3L, B234F head, one off intake and header, 04 Cobra IFS and IRS.
On to what's been up lately.
Decided to pull the cab, and reskin the roof, and replace the floor pans and cab mounts with proper panels.
Picked up a roof from a member here...
Separated it at the seam and as low as I could around the rest.
Cut the roof off the cab..
Found all the areas that didn't get paint from the factory had a nice coat of surface rust... Wire brushed it all and covered with Rustoleum converter paint.
Bob
SATURN5
Post by SATURN5 »
Got the roof fitted and strapped in place for welding.
Tacked it in place..
Smoothed the welds..
DC cab mounts waiting...
Bob
SATURN5
Post by SATURN5 »
Scored a 09 CV IFS over the weekend. Needs inner tie rods (bent), but otherwise in great shape. (That's the same little boy from above, not so little now)
Tried out some 18x9 FR500's I have sitting around for size... I'm thinking about 18 x 9 and 18 x 10 Anthricite Bullitts for a vintage look.
Filled the original gas opening. Will be getting the usual Mustang tank under the bed.
Working my way around the back seam. No matter how much I clean it up, whatever sealer Ford used is fighting me, making welding a pain.
Bob
390fastback
Post by 390fastback »
Not to hi-jack, but that is one beautiful SVO you got there!
74 F250 4x4
67 M250 4x4
62 unibody short box
couple old mustangs
couple old buicks
couple old internationals.....too much junk
Fordnatic
Post by Fordnatic »
390fastback wrote:Not to hi-jack, but that is one beautiful SVO you got there!
I concur!!! The F100 will be great also.
55F100
SATURN5
Re: 68 F100 SBFS build; CV, TR3650, DOHC
Post by SATURN5 »
Thanks, lots of hours building the SVO. While it's built to deliver over 500 hp on E85, I've got it set to a more streetable 350 hp, and I can run on pump gas.
Cut in and welded the pass side pan the past couple nights.
Pass side cab mount. Note that DC put the inner fender holes on the wrong side... :eek:
I'll weld them up and drill them in the correct spot.
Bob
F100builder
Post by F100builder »
Looks like some good work going on here! :thup: Glad to see you decided on the complete roof...a sunroof looks a little out of place on a pickup of this era IMHO. What are you doing about paint?
Patrick
SATURN5
Re: 68 F100 SBFS build; CV, T45, DOHC
Post by SATURN5 »
Thanks!
Been busy with some other projects, but I've made some progress with the driver's side.
Finished pass side.
Bad cab corner.
Replacement cut and tacked in.
Need to sand roll the lower bit, but otherwise done.
Dr floor and mount removed.
Need to patch someone's floor shift conversion mod....
Raised tunnel cover to make working on the T45 easier..
Kick panel repair.
Haven't settled on a final color yet. Dark Jade Green Met, Black, Midnight Grey met, Sonic Blue all being considered.
Bob
SATURN5
Post by SATURN5 »
Picked up the DOHC....
Looks pretty good inside for 150K miles.
Powerwashed the crossmember.
Worked on the driver's pan.
and what weekend isn't complete without a fire and a beer.
Bob
marz68
Post by marz68 »
Nice work! SVO looks good too!
Alstoyz
Post by Alstoyz »
You've got a good start there. NICE WORK!!! Digging the SVO also. :thup: What did you score the DOHC out of??? :fr:
1970 F-100 SWB Tubbed
1971 F-250 Crew-Cab Dually
1972 F-100 SWB 4X4
F100builder
You from PA or the northeast somewhere? I haven't seen Yuengling in a while! Nice work on the truck so far!
I've got a question about your raised trans. tunnel. I have a '70 that has the low non-C6 tunnel but I want to put the raised tunnel on for the C6 (I have an extra). Does it locate right where the low tunnel comes out and you just have to drill holes and add the clips?
Patrick
SATURN5
Post by SATURN5 »
Thanks. SVO's down while I work out some mods on the Megasquirt. Putting some Toyota COPS in with sequential fire.
Motor is out of a 97 Mark VIII. Complete takeout with wiring, accessories and harness/ECM. Worked a trade with one of the Mark VIII guys on the LVC forum.
Nope, the beer gods have finally allowed Yuengling in Ohio. I'm just south of Dayton in the burbs.
Mine was the same way. I just bought the raised hump piece and cut the tunnel. From there is drill and clip.
Finished the driver's pan tonight, onto the mount and patch the side of the tunnel. Then flip the cab on it's back, finish the underside and bedliner it. Goal is to get the chassis into roller status by Memorial Day. We'll see... Stay tuned!
Bob
Bob
marvin2
Post by marvin2 »
Looking good...keep the pictures coming. Floor pan and cab mount replacement is next on the docket for me too.
FYI, tha SVO is awesome! I've always had a thing for fox body mustangs.
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
