68 F100 SBFS build; CV, T45, DOHC/M122, Cobra IRS
derbydad276
Re: 68 F100 SBFS build; CV, T45, DOHC
Post by derbydad276 »
SATURN5 wrote:Boxed in my ugly original mounts...
[ Image ]
[ Image ]
[ Image ]
[ Image ]
Ran a boxing plate on the inside.
[ Image ]
[ Image ]
do you have any pictures of your original install on the rear end I plan on installing a t bird rear to my 67 and would love to save the 400 they want for the (bolt in) kit
SATURN5
Re: 68 F100 SBFS build; CV, T45, DOHC, MN12 IRS
Post by SATURN5 »
Nothing really different other then I boxed in the mounts for a cleaner look.
Bob
68 F100 Flareside, CVIFS, Cobra IRS, DOHC, M122, MS3, T45, 4.10, Cobra brakes
84 Mustang SVO, B234F, HE351, Full Cobra spec suspension and brakes including IRS, T-tops
96 Mark VIII, Complete chassis bracing, 03 Cobra wheels, Maruader converter, built trans.
SATURN5
Post by SATURN5 »
Figured out the steering on the cheap. 2004-8 F150 steering shaft, which I added 3" too. Modified the original (75) column shaft from 36 spline to the "D" with a notch to match the upper u joint. Cost... $45 shipped.
Bob
marvin2
Post by marvin2 »
Saturn5 that is great info on the steering shaft! Where did you pick one up for $45?!?
1970 F100 "Marvin 2" - Crown Vic IFS, 302, C4 (work in progress)
1970 F250 "Leonard" - 302, C6 (project in waiting)
1971 F100 "Walt" - 302, 3-speed on the column (Sunday driver)
2004 Mustang GT "Horse With No Name" - 4.6L, 5 speed (Retired daily driver / Friday driver)
SATURN5
Post by SATURN5 »
Thanks. :)
I've got a Mustang buddy who works at a dismantlers in Nebraska... ;)
Bob
SATURN5
Post by SATURN5 »
Whittled up a endcap/bearing assembly to replace the worn out factory stuff. Should last forever....
Installed.
Once I repaint the column, I'll keep it in place with 3 buttonhead screws.
Bob
That's some great custom work! :thup:
SATURN5
Post by SATURN5 »
Cobra manifold fits! Now for the rub... Apparently I bought two left sides... as shown in the auction.. I didn't look that close... Going to contact the seller and see if he's got a right side... Derp.
Clears the steering shaft by about a 1/2".
Bob
SATURN5
Post by SATURN5 »
A long cold winter is over. Picked up a fuel tank and got it installed.
Adjustable! Just like factory! lol
Found this on a Lightning forum. I think I'll copy it from the muffler back. Then adapt from the muffler to the BBK X Mustang pipe. I also bought a 98 Cobra intake. Going to build/mod the engine harness and run a Megasquirt II ecm...
Bob
Suhweeet! :thup:
Glbrantley
Post by Glbrantley »
This is some great stuff!! Giving me some ideas :thup:
1968 2wd swb
There's no replacement for displacement!
Mancar1
Post by Mancar1 »
Your doing some great fab work. :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
jurrien
Post by jurrien »
SATURN5 wrote:Whittled up a endcap/bearing assembly to replace the worn out factory stuff. Should last forever....
[ Image ]
Installed.
[ Image ]
I was planning on making This myself, but it's obviously a lot easier if I can buy it!
Where did you get the end cap and bearing?
Looking good!
Ford f100 '70 302
Audi S6 4.0 tfsi
BMW 525i '90 Turbo (project 500rwhp)
Full resto:
http://fordification.com/forum/viewtopi ... &start=135
SATURN5
Post by SATURN5 »
Thanks!
The bearing was a good used one from a tool we serviced at work. I just went thru our pile until I found one with the right ID. The end cap is something I whittled up in my lathe from Delrin. There's an o-ring holding the bearing in place.
Bob
48prerunner
Post by 48prerunner »
Some guy sells something like it on ebay , doesnt look as good as yours . I was just going to put a bearing in there, only wood lathes at work so not turning one there.
