BobbyFord Short Bed
BobbyFord
BobbyFord Short Bed
Postby BobbyFord » Thu Aug 28, 2014 5:05 pm
I'm finally ready to get back on my truck. I had a few setbacks but I'm ready to get after it. Rather than clog the website with a new thread for each aspect of my project, I decided to consolidate everything right here.
Here are some past threads:
Mustang Fuel Tank Install: viewtopic.php?t=46022
460 Engine Build: viewtopic.php?f=3&t=47192&st=0&sk=t&sd=a
Mini-Tubs (tub widening): viewtopic.php?p=549267
Axle Flip & C-Notch (my truck also has black powdercoated DJM lowering beams): viewtopic.php?f=5&t=56337&st=0&sk=t&sd=a
I've already bought a '69 Mustang shaker hood scoop but it is on backorder until October and I will include that in this project thread. It will require that I build an offset aircleaner to compensate for the engine offset.
Very soon I'll be adding a disc brake install. I have 1977 spindles and calipers. I'm going to get the calipers zinc plated and rebuild them. I already have most of the parts.
Because of the tall 460 valve covers, I decided to go with an aftermarket 8", dual-diaphragm brake booster, for clearance. I'll also install an aftermarket master cyl. and aftermarket proportioning valve. I'll bend my own hard lines. I might go with stainless. While I have the front end apart (again), I have new complete Moog steering linkage with '77 tie-rod ends, urethane radius arm bushings and new KYB Gas-a-just shocks.
Cipher43
Re: BobbyFord Short Bed
Postby Cipher43 » Thu Aug 28, 2014 5:33 pm
Im interested in seeing your hood scoop in action. I have been throwing around the idea of getting my spare hood and putting a shaker in it or the torino style scoop and switching hoods back and forth if i like it or not.
Greg
My Toys
Image...... Image......Image......Image
......1969 F-100................1968 F-250...........................57 S-100 IHC................71 CL350, 73CL450
original 360, T18 tranny, 9" with 3.25s
Project Rejuvenate Bill
viewtopic.php?f=22&t=69060
Calfdemon
Postby Calfdemon » Thu Aug 28, 2014 6:10 pm
:yip: :thup: :hd: :clap: :rock:
And Bobby is back in action! Cant wait to see the updates! :pop:
-Rich
Current toys -
Former toys -
crazyhorse
Postby crazyhorse » Thu Aug 28, 2014 11:28 pm
:yt: :woohoo: Me too. :thup: :fr: :fr:
sykanr0ng
Postby sykanr0ng » Fri Aug 29, 2014 12:45 pm
Regarding more clearance under the hood for the brake booster have you considered using a hydroboost?
The hydroboost gives more braking pressure and is smaller in diameter than a vacuum booster.
If you're going to use a "performance" grind cam your vacuum will be reduced, do you plan on having a vacuum pump?
Go fast trucks need stop fast brakes.
... I've got skills, ingenuity and no regard for maintaining any kind of historical preservation/authenticity...
BobbyFord
Postby BobbyFord » Fri Aug 29, 2014 9:01 pm
sykanr0ng wrote:Regarding more clearance under the hood for the brake booster have you considered using a hydroboost?
I have a healthy cam. I already have a drum brake booster on it and it clears the tall 460 valve covers, and seems to provide ample assist. It appears to be a 9" booster. I have about an inch of clearance from the valve cover. It is the drum brake fade that I'm trying to eliminate.
The stock 1977 disc brake booster is an 11 or 12 inch single diaphragm booster and will hit the valve cover. The aftermarket 8" dual diaphragm booster has more assist than the larger 1977 single diaphragm booster.
IN2FORD
Postby IN2FORD » Fri Aug 29, 2014 10:16 pm
Awesome build! Thanks for all of the documentation. It's helping me with my build!
Barry
sykanr0ng
Postby sykanr0ng » Fri Aug 29, 2014 11:38 pm
"The aftermarket 8" dual diaphragm booster"
^Who is that made by?
I'm about 95% sure that I'll go hydroboost, but info on other options could change that.
BobbyFord
Postby BobbyFord » Sat Aug 30, 2014 9:59 am
sykanr0ng wrote:"The aftermarket 8" dual diaphragm booster"
^Who is that made by?..
http://www.tuffstuffperformance.com/ind ... rd8660.htm
BobbyFord
Postby BobbyFord » Mon Sep 08, 2014 7:39 pm
Still waiting for a few parts for my disc brake install. One of my dust shields was damaged but I got the Ford part number and found an NOS one. I dropped my calipers off at the plater to get yellow zinc plated and dropped my spindles off at the powdercoater for some semi-gloss black powder paint. I have new inner & outer Bower/BCA bearings, National grease seals, Wagner pads, Wagner caliper hoses and the '77 Moog king pin set is ordered. I'm getting itchy. :)
Calfdemon
Postby Calfdemon » Tue Sep 09, 2014 1:00 pm
Can't wait to see the new parts!! Let me know if you need any help with anything. I am more than happy to come down and give a hand. :thup:
-Rich
Current toys -
Former toys -
BobbyFord
Postby BobbyFord » Tue Sep 09, 2014 7:42 pm
Here's the aftermarket dual-diaphragm booster, master and prop valve.
BobbyFord
Postby BobbyFord » Wed Sep 10, 2014 5:06 pm
Got my spindles back today :D
Calfdemon
Postby Calfdemon » Wed Sep 10, 2014 5:24 pm
Those look night and day from when we pulled them! :thup:
And that brake booster/MC/valve is sexy! 8)
-Rich
Current toys -
Former toys -
Mancar1
Postby Mancar1 » Thu Sep 11, 2014 3:49 pm
Calfdemon wrote:Those look night and day from when we pulled them! :thup:
Looks real good, but I don't know if I would go as far as sexy. :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Return to “Project Updates”
Who is online
