Been slow progress this past week with traveling to see family. Did get out to the garage for a few today. I am still working on the front axle but am missing a spring between the hub and the bearing. Here is a picture of what is on the Passenger Side.
- Manny
I have not forgotten you but just getting back in the groove here. I've got some springs here if you need one and a cup. Just want it added to your list. Pm me we will get a box of junk headed your way.. I promise pictures within 36 hourshfdco4 wrote:Been slow progress this past week with traveling to see family. Did get out to the garage for a few today. I am still working on the front axle but am missing a spring between the hub and the bearing. Here is a picture of what is on the Passenger Side.
Awesome sir!
- Manny
Here you go got pretty much the whole axle don't want to part it to death but can get you squared away. I also have those hub springs your hunting. Sorry for the crappy pictures the phone for one versus the camera second that axle is buried.
let me know.
let me know.
Man I wish you were closer. I would love the spring for sure. I wouldn't mind the caliper brackets too, but only if you are taking it apart.
- Manny
hfdco4 wrote:Man I wish you were closer. I would love the spring for sure. I wouldn't mind the caliper brackets too, but only if you are taking it apart.
Pm me your address can ship some junk..
- Manny
Just hit up Ebay myself to hunt there is tons of reman calipers with pads and brackets from 60$-$120 I saw but redone ready to go may be something to consider. We will get it sorted! Pm your address I will ship you a spring
Holy cow Manny you have an axle farm there!
Hope you get that axle all squared away. It stinks when you get stuck on parts. Still rootin for ya!
Kyle
Kyle
Oh I am good. This isn't really holding me up yet. I just want to get the front axle mounted back onto the frame so it can be moved out of the garage. Need to get to work on the cab now.
- Manny
hfdco4 wrote:Oh I am good. This isn't really holding me up yet. I just want to get the front axle mounted back onto the frame so it can be moved out of the garage. Need to get to work on the cab now.
I checked the 60 brackets i got look like it may be the winner gonna bolt it up check and take photos. How soon you need them? obviously sooner the better.
No rush sir. I am hitting the front axle hard just to get it mounted and moveable. The frame is going outside for the winter. Today we were out in the garage making a traditional Italian Christmas Pizzelle cookie. We have to use the grill so she can heated up the cookie press. Since we were both out there I got the two top nuts tightened on the ball joints and installed the cotter pins. Now I need to clean and paint the tie-rod. I also have to install the new Axle U-Joint on the short side. Only a little progress but still progress. It was fun working out in the garage while it was snowing.
I hear ya! I love having a warm fire in the garage when it's nasty snowy outside. I'm excited for your frame to be a roller so I can see your cab work - you do good work.
Kyle
Kyle
Thank you Ranger! It does feel good to get complemented on something I truly love doing.
I just have seen your attention to detail and know there's not a square inch you have overlooked. The cab will be fun to watch. I kinda wish I had pulled my cab. Maybe next time I redo it.hfdco4 wrote:Thank you Ranger! It does feel good to get complemented on something I truly love doing.
Kyle
Kyle
I just have seen your attention to detail and know there's not a square inch you have overlooked. The cab will be fun to watch. I kinda wish I had pulled my cab. Maybe next time I redo it.[/quote]
Oh I am sure I have overlooked things, but they will show up and get done. I want to get the floor work done on the cab so I can coat the underneath of the cab. That way I can work on the dent in the cab.
