1968 F-100 Ranger - RestoMod Daily Driver
SuperDodge
Re: 1968 F-100 Ranger - RestoMod Daily Driver
Post by SuperDodge »
390bump wrote:I was looking at the MP Brakes kits on their site and it says 15" wheels will work. Saw your post and now I'm not sure... What make are those wheels you have? They look very similar to mine... They look like 15x8 but as they cast aluminum or forged? Do you have any critical measurements for the inside part of the wheel to share that I could compare to see if they would work with the MP kits? Is the issue the same for front and back? Thanks!
The wheels are cast aluminum 15x8's. They actually did clear the brakes with a 1/4" adapter installed. You would never drive it this way because of how the MP Brakes hub is made, but it worked to roll it around the shop for a while. I would check and recheck the dimensions and talk to MP Brakes before placing an order. I wasn't too worried about it because I knew I was replacing them with 20" wheels in very short order.
pleasaw
Post by pleasaw »
Ok thanks
