Raven: The Saga Continues
Re: The Start of my 4x4 Build
Congratulations, now keep at the house hunt. The one thing I can say about the house hunt is find the area you want first, you can always make the house work. The perfect house is no good in the wrong place. Just my two cents.
- Manny
Congrats on the title that is cool to have. Don't have to have one in Georgia but still got mine. Good luck with the house.
- hdman90
Thanks guys,
Going to look at one this afternoon. Great location, nice house, nice property, but no garage... Which is okay, I'd rather build my own anyhow
I'll keep ya'll updated!
Thanks again!
Thanks again!
- Manny
Building it always works out great!!!hdman90 wrote:Thanks guys,
Thanks again!
Cool man hope it all works out for ya. You can always build the truck in the driveway. Happy hunting!
Kyle
Kyle
Any updates?
- hdman90
I did stop out at the '70 this weekend to determine what transfer case the truck has. Found out it has a Dana 24 transfer case. I need to find a rear drive shaft for the truck. I'm very curious to see if the truck will move under it's own power, but I don't want to hurt anything either. Since it's been sitting so long...
So if anyone reading happens to have a rear drive shaft for a F-250 4wd with a Dana 24 Transfer case, let me know!
Still waiting on the title to arrive.
Thanks again for the interest!
- cstoyer
Good to see things are moving forward and good luck on the rebuild. I'm in the middle of the restoration on my F250 4x4 so I know your excited to get started. If you plan to rebuild the Dana 24 and NP435 let me know as I did mine and could and may be able to give you a few tips.
cstoyer
cstoyer
68 F250 4x4
- hdman90
Thanks Cstoyer! I will certainly keep that in mind! Turns out the property that I am storing the '70 on has a rear driveshaft he will let me buy for $100. I'm going to see if I can talk him down to $75, then I'll stop some warm-ish weekend and swap them out. Ill also want to drain the oil (currently a very thick sludge) and replace the bottom radiator hose, and fill with coolant before trying to fire it up...
That's the plan for now anyhow.
Any updates on the house search? Interest rates are still low so good hunting!
- hdman90
Sadly, no. We haven't even looked at any recently. The area is a really tough market to buy in. Once a house is listed you pretty much have to look at it and put a bid in the same day it is listed or someone can buy it out from under you. We've had it happen a few times already.hfdco4 wrote:Any updates on the house search? Interest rates are still low so good hunting!
Nothing has been listed lately in the area we want to buy, so sadly, there are no updates to tell on the home front issue
- 71PA_Highboy
Hey,
It has been a few years but when I was building mine, I got a lot of parts from Brian Horner's Stateline Auto Parts over in Sugar Grove.
Ya gotta go all the way up the hill and take a slight left... he kept the old stuff up there. I picked up a divorced 205 and lots of other parts there.
Smethport/Coudersport had some decent junk yards that aren't as picked over. I also picked up a KingPin HP D60 from there for $100, so you never know what you will find.
Good luck! I know the challenge you are facing ... NWPA is a real rust bucket!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- cstoyer
cstoyer
cstoyer
68 F250 4x4
- Manny
Got some rust experts around Garrett county Maryland. That is rough up there hope you get her up and running!
- hdman90
Well, not much of a physical update, but I am making progress on a couple issues.
1. I got the title in the mail a couple days after Christmas, so that's good that it's officially mine! (only took two months to process )
2. We looked at a house last week and they have already accepted our offer, so if all goes well, the bump will have a new home!
3. A friend that I've sold/traded parts with a few times found a whole parts truck for $600. We are discussing going in halves on it; he would take the bed/hood and I would take cab/doors/fenders, and I would do all the driving/transporting.
Things are lining up, hopefully all goes well!
