harmonic balancer and pulley
idaford
Post by idaford »
I have a 1969 ford f250 with a 360. I am converting it to power steering and need to change the single groove pulley on the crank to a 2 groove. I found a 3 groove pulley off of a 1973 f250 so I grabbed it and the pulley for the fan. Can I just put the crank pulley on with the existing harmonic balancer or do I need to change it?
tnlprt
Re: harmonic balancer and pulley
Post by tnlprt »
both pulleys will be 3 bolt
Yes They interchange
idaford
Post by idaford »
That's what I wanted to hear. Thanks
Manny
Post by Manny »
idaford wrote:That's what I wanted to hear. Thanks
Got a bunch of Fe pulleys here if you need some other stuff. :thup:
