Degreeing cam info
Engine-related FAQs
Moderator: Ranchero50
Dragon
Degreeing cam info
Post by Dragon »
For maximum performance, each Crower camshaft is carefully designed to open and close the valves precisely, in relation to crankshaft rotation and piston position (this is called valve timing.) That’s why it’s so important to make sure your new Crower
camshaft is opening and closing the valves as it was design to do.
It used to be you could install a new Crower camshaft on the stock timing marks and be within 1° + or - of our recommended valve timing figures. Stiffer pollution control standards changed all that as automobile manufacturers advanced or retarded valve timing over the years to clean up dirty emissions.
Nowadays, you can’t rely on stock timing marks on newer motors for proper installation of your new camshaft. You should degree your camshaft to verify valve timing figures listed on the timing tag supplied with your camshaft. In doing so, you’ll achieve maximum performance, torque and satisfaction.
As that says on pollution motors the timing is a mess not on the FEs they never put retarded cam timing gears or profiles in. So if you are dropping in a near stock or mild cam in an FE don't waste your time degreeing the cam. :2cents:
Old Fords Rule
Was a Ford Service Tech
71 F250 with Shell Car 390 NP435 Dana 60 3.73s, PS, PB, 750 EC VS Holley Accel Points Eliminator.
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
