Speedo gear
Bunkerhillbilly
Speedo gear
Post by Bunkerhillbilly »
Het guys, anybody know how many teeth are on a speedo gear for 3:50 ratio rear end?? I got a bunch of em in a drawer but don't know which one I need.
colnago
Re: Speedo gear
Post by colnago »
That's going to depend on the groove count on the transmission's output shaft, the rear-end ratio (3.50, from your post), and tire size. I have a C6 with a 7-groove shaft, 4.10 gearing, and 245/75R16 tires, and I think I'm using a purple gear. This is probably not what you want to hear, but it might end up being trial-and-error for you.
Joseph
On edit, Ford also used gears with long "snouts," and gears with short snouts (the narrow plastic shaft that goes beyond the geared portion). I think this helps keep the gear in the right place, relative to the top of the output shaft. As I recall, you want the short snout (could be wrong on this, so I hope someone comes in to correct if needed).
