1969 F100 compatible rims/tires
69F110
Postby 69F110 » Sun Jan 07, 2018 10:59 pm
I am sure this has been asked, yet doing every search I can think of does not answer my questions.
I am been blessed to have my 1969 back. (It was gone for five years). Now that I have it back, it has been sitting that entire time in the harsh Louisiana weather (extreme heat, high humidity, rain, etc.) and every tire is rotted. I am having a hard time locating 15 inch rims that fit and 235/75/R15's as well. Not being versed on tire and rim sizes- I figure I would call upon those of you who know these things.
Standard issue 1969 F100 LWB. 15" rims that 5x5.5 with a standard tire size of 235/75/R15.
Would a compatible 16" rim also be 5x5.5 pattern? If so, is there a vehicle out there that has that pattern? Perhaps a ford or dodge truck that has a 16 inch rim that will bolt right on with no adapters?
Or- is there another 15 inch tire that I can put on a 15 inch 5x5.5 rim that will work? Obviously not every 15 inch tire will fit- am I correct in thinking that? I do have enough old 15 inch rims that I can clean up and plasti-dip to look half way decent. I just do not know what other sizes would fit...I am thinking that 265/75/R15 would fit on the rim and work, but have no prior experience or knowledge to know if that is correct.
Well, there it is. If you know, I thank you in advance for your time and attention to these questions.
Steve Davis
Pastor and U.S. Army Retired
1969 F100 Ranger LWB, 390 and 3 on the tree
HIO Silver
Re: 1969 F100 compatible rims/tires
Postby HIO Silver » Mon Jan 08, 2018 8:58 am
Wheels from half-ton Econolines should fit the bill... both 15- and 16- inch varieties.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
JoshT
Postby JoshT » Fri Jan 12, 2018 11:55 pm
If you are looking for OEM wheels, any F-150 or Bronco wheels up until 1996 have same lug pattern. As HIO Silver mentioned E-150 wheels fit as well, but I don't know what year they changed.
1968 F-100 4x4 long bed - 390 FE - NP435 w/ Dana 21 - PS & PB conversion - 32x11.5R15 - 1" S.L. & 2" B.L. (to be removed) - Homemade tube bumpers - Warn 8274 - Currently wearing 1970 body
Parts Needed: long bed - hood - passenger fender liner
Would consider a cheap parts truck with all of the above
Ohiotinkerer
Postby Ohiotinkerer » Sat Jan 13, 2018 8:38 am
Another option you could go with like I did is this.......
https://www.wheelvintiques.com/o-e-chev ... inish.html
They look just like stock rims and come in different widths - I went with 15X8's with 31-10.5's on mine mostly to help drop the rpm's a little........I have a picture of them unmounted and mounted in my gallery......
As far as tires I went with these......
http://mastercrafttires.com/Tires/Light ... r-LTR.aspx
They make these in a 235/75-15 and I have had pretty good luck with them........don't know if they sell Master craft down your way though..... :?
"Life is a garden - dig it"........... :thup:
1968 F100 Baseline 2wd - Rangoon Red - 360 2bbl - T18 - power steering and manual brakes
1997 Honda CBR 900RR
1977 MonArk 14 ft jon boat with a 1963 Johnson JW-18 3hp outboard
Return to “Suspension / Steering / Brakes”
Who is online
Users browsing this forum: 19Allen67
