Aftermarket power steering cooler
Ohiotinkerer
Post by Ohiotinkerer »
Bought a generic p/s cooler and trying to figure the best place to mount it - I came with zip ties but don't want it rubbing on the radiator (its the original) and can fab a mount for it but unsure of what would be the best location for it - any suggestions greatly appreciated!
1997 Honda CBR 900RR
bluef250
Re: Aftermarket power steering cooler
Post by bluef250 »
Is the power steering running hot? Why do you need the cooler? Stock units were placed on the return side and mounted on the pump. The stock unit is 6 to 8 inches long.
Ohiotinkerer
I've seen them on bumps with the same setup I installed on mine so I figured it was there for a reason thus the decision to put it on mine. I was thinking that maybe there was a better spot to put it for more airflow and maybe someone had found a better location to put it than the stock Ford setup.......... :?
