Emergency flasher switch location
willowbilly3
re: Emergency flasher switch location
Post by willowbilly3 »
I think if there ever was any rhyme or reason it all went out the window long ago with dealer installed packages and trucks that have been wrecked and recabbed early in life. And while we are at it some trucks seem to have 3 holes and some only2 in the dash area where the lighter/choke/emergancy flasher/cargo light switches reside.
fonzf100s
Post by fonzf100s »
Hi to all, just joined, great site! :clap: I bought a '69 stepside this summer, and after searching :hmm: , found that my plug for the flashers was in the glove box, so that's where it is now after a trip to the junkyard for a switch.
Also, my dash just has two holes on the right, choke and cigarette lighter knobs.
Heyyyyyyyyyy, keep 'em cool, keep 'em on the road!
willowbilly3
Welcome to the site. When you get time you might want to peruse the sight. Keith has compiled a good bit of info on the 67-72 bodied trucks.
cobraF100
Post by cobraF100 »
fonzf100s,Welcome to the Site and it's Good to have you aboard.... :hi:
Chris
Never Forget Our Soldiers
fonzf100s
Post by fonzf100s »
Thanks guys! Been around the site and the junkyard a lot in the last four months, it's great to be on, hope I can be of help to someone at some point.
Ron S.
willowbilly3
Any good dash pads up your way?
fonzf100s
Post by fonzf100s »
If there are I haven't found them. Mine has a replacemnet dash cover that someone has put on from maybe LMC, or Carpenter. If I run across any, I'll let you know. Any particular color you're after, or just any that you will paint?
Ron
willowbilly3
Can't be choosy if a good on pops up. Mine had one of those covers over it too. It doesn't look too bad but sags down in front of the instermente a little.
bumt72
Post by bumt72 »
fonzf100s, check out my parts list in parts wanted. Help REALLY needed, a local salvage yard want $200 for the toyota power steering box :eek: Also (he says trying to keep this post on topic) on the emergency flasher location, mine is in my toolbox at the moment, hope this helps.
Kep
Kep
1972 F250 Da Big Ugly Man TruckDa BUMT
1961 F100 Stepside (Father/Daughter Project)UnNamed
michaelbrainard
Post by michaelbrainard »
I suppose this info is redundant but here it goes:
my 69 with factory air has it located under the dash to the right of the steering column...
The 67 that I gutted last week had it mounted in the glove box ( no air )...
I took the switch..any one need it?
