steering wheel horn
patruccio
steering wheel horn
Postby patruccio » Sun Oct 08, 2017 5:31 pm
I'm having issues with my horn, I recently bought a new steering wheel and horn ring.
The wheel fits perfect and looks great. The horn ring is a different cat, there is nothing under the
horn ring that has a metal surface to make contact with the brush assembly. I drop the brush assembly
in the hole and it seems to be way short for contact. I'm lost, any help would be appreciated.
Pat :help: I have a 68 Ford f250 2WD Camper/Special
colnago
Re: steering wheel horn
Postby colnago » Wed Oct 11, 2017 10:53 am
Can you post pics of what you have, showing the "innards" of the horn button, etc?
Joseph
"Sugar", my 1967 Ford F250 2WD Camper Special, 352FE, "T" Intake with 1405 Edelbrock, Duraspark II Ignition, C6 transmission, front disc brake conversion.
bluef250
Postby bluef250 » Wed Oct 11, 2017 7:47 pm
A longer spring on bush assembly may be needed.
71Fe2O3
Postby 71Fe2O3 » Wed Oct 11, 2017 10:03 pm
There are two of the springy horn contacts, and you should be able to find a schematic on this site showing the internal anatomy of the steering column that will help you to get it together properly. As far as I know, the spring contacts come in only one size for these trucks.
Fred
patruccio
Postby patruccio » Thu Oct 12, 2017 11:42 am
Thanks for the reply's.
patruccio
Postby patruccio » Fri Oct 13, 2017 11:28 am
I found a longer spring for the brush assembly but there is no
metal on the retainer plate to make contact?
71Fe2O3
Postby 71Fe2O3 » Fri Oct 13, 2017 9:48 pm
Have you checked the schematic to see if you have all the parts?
Also, do you know that your column is the original?
A previous owner may have put one in from a newer model that may have some different parts.
Fred
patruccio
Postby patruccio » Fri Oct 13, 2017 11:10 pm
I have all the parts I purchased from LMC. I'm the 2nd owner and there
has been no alterations to the column.
patruccio
Postby patruccio » Sat Oct 21, 2017 9:11 pm
:evil: I'd like to post some pictures but can't seem to resize them to email.
Return to “Interior”
Who is online
