15 x 8 5@5.5
70xlt
15 x 8 5@5.5
Post by 70xlt »
How much should I pay for 15 x 8 in ford rims?
Re: 15 x 8 5@5.5
Post by cep62 »
It depends on what style and condition.
If you're talking the mid 80s spoke style with the center caps and trim rings.?
maybe $20 - $60 ish.
If these are going on a '79 or earlier 4X4 you might need a 1/4 inch spacer to keep it away from the tierods.
rbmead
Re: 15 x 8 5@5.5
Post by rbmead »
I just purchased a set of Steel wheels from Summit via Ebay for around $340 with free shipping. currently getting powder coated. but I want the factory look.
1972 Ford F100 SWB 4x4
HIO Silver
Re: 15 x 8 5@5.5
Post by HIO Silver »
Wheel Vintiques Series 62 steel wheels are like $85 each thru Summit Racing.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
rbmead
Re: 15 x 8 5@5.5
Post by rbmead »
That is where I purchased mine.
geradr4
Re: 15 x 8 5@5.5
Post by geradr4 »
rbmead wrote:That is where I purchased mine.
Nice choice. What tire size are you planning to put on it?
Ohiotinkerer
Re: 15 x 8 5@5.5
Post by Ohiotinkerer »
Same choice i made from Summit............I'm running Mastercraft Courser LTR 31-10.5's on mine.......photos of them in my gallery......
1997 Honda CBR 900RR
Manny
Re: 15 x 8 5@5.5
Post by Manny »
Like the steelies they are always a good option from wheel vintiques. Only other option that I like but more expensive is the us mags indy 101. :thup:
rbmead
Re: 15 x 8 5@5.5
Post by rbmead »
Not my 1st choice. that was what was on the truck. plan is to swap later. first time out of the garage in well over a year. rear leaf spring attention is next.
70xlt
Re: 15 x 8 5@5.5
Post by 70xlt »
Thanks for all the response. I ended up putting us mags 17" X 8" with 235x75x17 on it, although one size bigger on the rear. I had installed DJM lowering kit and they fit fine. I tried uploading pic but no luck on my end.
Thxs
70 XLT
Busboy
Re: 15 x 8 5@5.5
Post by Busboy »
I buy them from the local salvage yards, sandblast them, prime with epoxy, paint with Wimbledon white acrylic enamel with hardener. They look great.
1967 F-100 4x4 custom cab.
