1967 radio install
Bobaloo2
1967 radio install
Post by Bobaloo2 »
I used the Volvo adapter, along with the metal cage that came with my radio, and found that I had to take a Dremel tool and cut out the entire indented area in my dash for the radio to go in. I removed the ears from the Volvo adapter, and drilled two holes in the top edge to secure it to my dash.
Apparently all 67 dashes were not made the same in the radio hole area. ? However, I am delighted with the results.
Bob
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Re: 1967 radio install
thats right the 67 had a smaller type of radio than the 68-72 trucks did.
thethump
Post by thethump »
Nice job. I've been considering something like this for my 72, but might just build a stand along box system that sits on the hump to keep the AM original. All I got to listen to when I roll down the road is my right side manifold gasket leak and the radio just whistles.
David | Knoxville TN
My 1972 F100 Ranger XLT is For SALE
ImageImage Image
This great song mentioning a flatbed Ford was released on May 1, 1972, the band’s first single. 72 was a good year, ah yes.
Unfortunately, the ladies above are not my girlfriends.
Bobaloo2
Post by Bobaloo2 »
I hear you brother, my 1980's AM-FM Cassette had a broken antenna and I have a passenger side exhaust leak at the ex. manifold. I am ready for some tunes.
Small world.
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
in my dreams at night no mater if i am being attacked by monsters or what. i hear classical music in the back ground. how wierd is that?
Bobaloo2
Post by Bobaloo2 »
First thing I would do is buy a big bottle of Ranitidine at Sam's Club.....It may be something you ate.
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
my460pjb
Post by my460pjb »
:thup: Like wise
Sit down, shutup and hold on!!!!!!!!! I'm climbing to the top. "NO FEAR!!!!!"
fordamericana
Post by fordamericana »
Bobaloo2 wrote:I used the Volvo adapter, along with the metal cage that came with my radio, and found that I had to take a Dremel tool and cut out the entire indented area in my dash for the radio to go in. I removed the ears from the Volvo adapter, and drilled two holes in the top edge to secure it to my dash.
[ Image ]
[ Image ]
Bob
You wouldn't happen to have the part number of that install kit you used would you?
I likes My FE I does...
67fordkc
Post by 67fordkc »
Here is picture of my radio install in my 67.
jcolville
Post by jcolville »
how did you guys attach the mounting cage and the volvol bezel to the truck?
