Weird instrument cluster gauges
67 ford f100s rule
Post by 67 ford f100s rule »
When I turn on my headlights my fuel gauge,heat, and oil pressure gauge all go higher then usual. what could be causing this? :hmm: Also when my headlights are on my turn signal arrows blink opposite of which way a turn them on.
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
Re: Weird instrument cluster gauges
when did any or all of this start? has it always blinked backwards? if so maybe someone switched the bulbs wires from one side to the other side. the gauge problem is a feedback of some sort. thats all i can think of right now.
67 ford f100s rule
i tried replacing a bulb because one sides bulb is out. after that it started flashing backwards
Jeff Penland
was it the correct bulb? did it maybe get stuck in the socket funny?
TX69F100
Post by TX69F100 »
May be a grounding issue.
Brent
1969 F100 Ranger 390/C6 <--- Build thread
Doug F
Post by Doug F »
I had similar issues when I was tracking down my electric problems and it turned out to be the ground. Could be corrosion???
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
