dash controls in 1967 f100
element7878
Post by element7878 »
Im curious as to what the 3 temp controls were and what they controlled in the truck..also what they hooked to to make them work. I was looking at my dash earlier...i know i have two of the knobs, but im to lazy right now to go outside and see what they were for....i think they said defrost and control, but i could be wrong...and one i guess is missing... the one all the way to the left because there is just a hole...Its going to be getting cold pretty soon and was just curious as to what all i had to do to get the heater working...i have the blower fan under the dash, but it isnt hooked up, not even sure if it works...and im not sure if the two knobs i have are even hooked to anything...
1967 ford f100 Shortbed
Ford 360,edelbrock intake,holly 4bbl 600,rv cam
San Antonio, Texas
Re: dash controls in 1967 f100
one is the fan switch. one is probably defrost . i cant think of what the third one is for. maybe for floor.
Caseys71
Post by Caseys71 »
I think the closest one to the driver is the fan switch, then defrost, then temp control or something like that :lol:.
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
doesnt the fan switch also pull as well as twist?
Caseys71
Post by Caseys71 »
Yea it does, not sure what it pulls for though either defrost or temp control meaning I'm still not sure what the 3rd one is for. I will look at my '67 and find out tomorrow for sure.
Casey
red403
Post by red403 »
The 67 had a single switch to run the heater unless you have the deluxe heater option. The deluxe heater had 3 controls in the middle of the dash. The left one is for the fan control and heat control, the middle is for temp control, and the right one is the defrost or floor.
element7878
So my question is, what did they all hook to, and what all do i need to get my heater working?
San Antonio, Texas
the only thing i could find is this. http://www.fordification.com/tech/image ... sh-air.gif
this is for the freash air heaters and not the deluxe heater with the three knobs. and this isnt a very good diagram as far as i am concerned. i don't have my 67 here. so i cant tell you exactly what cable goes to what. but it will be similar to the 68-72 deluxe heater cable arrangement. but i dont have one of those to look at. here is a picture that doesnt help much of the 68-72 heater controls hooked to the heater box.
red403
Post by red403 »
Is the heater in the 67 the same heater as the 68-72 or did they change the box aswell as the heater controls?
the boxes are the same 67-72. its the fresh air vs deluxe heat that is the difference. and i think the only difference is the controls and the rubber boot. i think. there is a recent thread with soem pictures in it of the fresh air heater. but i can't remember what the thread was called. i'll see if i can find it.
