speaker location
- 69f-100
speaker location
i have a 69 f100 ranger swb 2wd. can someone tell me where the correct speaker locations are for this truck. i have a speaker in each side left and right kick panel, but im not sure if they are supposed to be their or if someone put them their. if some know where the speakers are supposed to be in this cab please let me know.
- jbohall001
Re: speaker location
I have a 69 and a 70 and on both of them the speaker location is in the middle of the dash. But if you don't care about "correct" you could leave them in the kick panel
Vi hilser til Day
Vi hilser sønner Day
Vi hilser the Night og hennes døtre
Se på oss nå, med myke og ømme øyne
Velsign oss som sitter her
Vi hilser gudene
Vi hilser på gudinnene
Hilsen til deg; hellige Earth
Gi oss en gave av kunnskap og visdom
og la oss få hender som kan helbrede.
Vi hilser gudene
The dash is the stock location as far as I know. I have them in my door panels and headliner in my two trucks
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
- 69f-100
ok thanks guys. i just wasnt sure so i thought i'd ask.
The correct location for a 69 is one in the center of the dash. For 70-72 I think, maybe only 71-72 the FM stereo had an option of having one on the lower part of each door. I put a 6x9 on the door panel part of my truck and it sounds great
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
71/72 had the in door speaker option. http://www.fordification.com/tech/67-72ID_01.htm at the bottom of the page.
Not sure of the age of this post but just my $ .02 added..
I have a pretty extensive background both in 12 volt and Audio itself. And my opinions are just that. However, work with me here. If your concerned with an aesthetic approach to OEM placement, keep in mind whats available and known today wasnt thought of with our trucks back then. AM was just beyond all the rage back then and the need for stereo compensation was, well... different thoughts existed back then.
If you take a speaker and put it in the top corners of the dash and measured each distance to the corresponding ear in the drivers seat. the Drivers side dash speaker would be (hypothetical numbers used here as ea application has many variables) say 21" Left and 39.5" for the right speaker. Now lets take the speakers to the front doors. Now the drivers side location is 36.75" from the left ear and the passenger door location is now 52" from the right ear. Move the speakers forward into the kick panel areas. Now we see that the drivers side moves away farther by moving it forward. Lets interpret that as an almost 10" gain. so now we have a 46.75" distance to the left ear. and since the right speaker is only moving forward and NOT farther away we only gain 3 more inches in distance but the speaker is moved 10" forward. We now have 55" in total distance from the right ear to the right speaker.
Now if your with me still after putting this picture in your head. We started out with the right dash speaker the greatest distance away compared to the left side dash speaker. There is a difference in distance of 18.5". By moving the speakers into the kick panel we ended up with a left speaker distance of 46.75" and a right speaker difference of 55" totaling out to a lesser 8.25" of distance. Now before you shake your head at me understand what we did mentally was play with and prove time delay differences in stereo sound. by placing the speakers in kick panels we lessen the time delay and equaled out the sound.
Hope that helps put a thought or two in some peoples heads...
72' Ford F-100 (PROJECT:: Modern Restoration)
01' BMW 328Ci *SOLD*
05' Scion xB *Marital Mutiny*
99' Civic EK Hatchie *SOLD*
92' Civic EG Hatchie (auto-X/Roadcourse/DD) *SOLD*
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
The date of the post is at the top. Thanks for the info. The piture thats been put in my head is of the cold one I will have latter.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- TNIceWolf
It helped a lot filling in some missing info I needed for a planned upgrade I am researching here in another thread where I needed info on the wiring routing and placement of door mounted speakers. Very good information to help make a "sound " decision with.Undrstm8ed wrote:.. yea still trying to familiarize myself with this format of forum. I figured it may be useful to someone else who may stumble upon it as I did.
Thanks!!
Find 'em....Buy 'em....Fix 'em.....Drive 'em....Love 'em
HHC 4/67AR.... Bandits.....88-92
Presently in the stable
1969 Ford F-350 DRW
1989 Chevy S-10 Tahoe ( It gets me to work and back and fetches parts and groceries)
1981 Buick Regal ( My deceased uncles last project/driver....renamed project Regal Eagle to be finished in his honor)
1990 Ford F-150 ( Miss Yvonnes Daily Driver )
My F-350 project http://www.fordification.com/forum/view ... 22&t=41744
1969 Ford F-350 DRW
Yea I am a bit more into the SQ than SPL. Ive been there done that and still have both kidneys.
What I like more is sitting people in a vehicle that is abnormally isolated from outside noise (very quiet) and listening to their own music CD's and letting them hear things they've never heard before. Clarity is key with me. My system will have a 12 yr old head Unit (Eclipse 7001) with the matching 6 disc changer unless I can find a 2nd one to Daisey chain the two together before I finalize plans.
Fed through Audioquest http://www.audioquest.com/(LOOK>Interconnects>analog>Diamondback cables) to an Audio Control EQL 13 band eq with built in Line Driver/noise gate (9volts RCA output lets the amp work less harder with higher signal quality for less distortion and background noise) which feeds into my Eclipse 4ch amp 50x4. Trust me, Unregulated power supplies make a world of difference when used correctly. through more AudioQuest Speaker cable, type4 for all the mids and highs, type6 wired through the sub enclosure. The 4ch amp will run 3ch, 50w to each kick panel and door which will run a 6" Midbass driver (Door x-over 80-400hz), 5.25 Mid range w/component tweeter (kick Panels x-over 400hz up), A second tweeter mounted in the lower A/pillar or molded into the Carbon Fiber dash cover I'm going to make will be aimed at the rear of the rear view mirror.
This will allow me to maintain mostly a 4ohm load across 8 speakers setting the front stage and allowing me to pinpoint more detail with some rather nice separation. It will also raise the sound stage itself up higher in the cab giving much more presence. The 3-4th channels will be bridged and directed to three 8" Diamond Audio D3 8ohm subs (which will offer me a safe 2.8 ohm load when done at not quite 200w mono) where the OEM fuel Cell was in an enclosure molded to the back of the cab (possibly also done in Carbon Fiber and MDF).
Since its such a small space there is no real need for rear fill (speakers) in the cab. The bottom end is tight and precise and will be in sealed enclosure to maintain that and its small size. I like a little bump in the bottom but I've maintained keeping nearly 5-8K worth of gear in nearly every car I've had. Its tuned to enjoy and wow from within the inside. Only opening of the doors or blatantly running down the street with the windows down gives it away. Even then, the total system power of 200w allows me to maintain a small foot print in the sound off. Much will be left unseen without pointing it out specifically in the truck. I still believe in the theory of "If you cant see it, you cant steal it"... Eliminating would be thieves to have little or no notice im coming down the street. On top of the system being prepped from rattles and buzzes thanks to Dynamat, The enclosure itself will be custom designed and tuned for particular frequency band that does NOT introduce buzz or rattles from the frequency's it will produce based upon its needs and my wants.
Therefore again keeping my stuff longer, and not making someone else want it more than I
Paint that in your mind
that is some real good sounding advise on speaker positioning.
Love sharing what I've learned through the years... Ha at one time I wouldn't buy a car unless I could mentally take it apart in my head and put my thoughts of self personalization or engineering into it first..
