Storage box for Cab
Storage box for Cab
Hi Folks,
I own a 1968 Ford F100 (automatic) and would like a storage "box" to weld or bolt to the transmission hump to hold hunting stuff like ammo, flashlights, pocket knife, sunglasses etc. Have not been able to find anything online. Any thoughts or comments or lessons learned on what can be used for this purpose would be appreciated.
Regards,
Jack
Regards,
Jack
- 67mann
Re: Storage box for Cab
Skys the limit and what ever your imagination comes up with,because I don't believe any thing specifically is made for our trucks like that
How bout an old school ammo box
I agree and have considered a metal ammo box. The one I have is too narrow and I will continue to look around for one with different dimensions.
- hivewax
I was just thinking maybe you can get a bunch of narrow ammo boxes (3 to 4) and welding them together side-to-side.
Loren Pittack - EngineeRunner, Corp.
'97 Dodge 2500 - 12V Cummins, NV4500, hydro-boost, DANA 80 rear (power-train donor)
'68 F250 4x4 Crew Cab Short Box - work horse parts/car hauler - http://fordification.com/forum/viewtopi ... 22&t=60632
'66 Mustang FASTBACK GT - modified - http://engineerunner.com/vintage-ford.html
Some of the 1994 f150/250/350 had a cup holder at the front of the seat I thought it had a little spot for junk just ahead of the cup holder.
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Being a wood worker I just custom build my own. Or with a rivet gun or welder you could fabricate just what you want out of metal.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- HIO Silver
Has anybody tried Tuffy Security ??? http://www.tuffyproducts.com/default.aspx
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
I thought about welding several narrow ammo boxes together as well. I have a large ammo box that would work, but it is really deep and not as wide as I would like. The Tuffy site had some neat stuff but did not see anything that would work.
Interestingly enough, a 12 pack beer box placed on its wide side is the right size for me (or a little longer and taller). Something with some slots perhaps so that you could
place dividers and create compartments of different widths.
Jack
Jack
Being a woodworker also I have had a custom wooden box in the bump on the hump for about 25 years. One small metal screw is all it takes to hold it secure if built right and makes it easy top remove. Mine has two drink holders and then a flip up lid in front where my conceal carry pistol and other Junk is put. I would be lost without it. I have not had a glove box in years. Too far away to reach in a hurry anyway.
Clint
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- 71PA_Highboy
Pics Clint! We need pics...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
