72 ranger door panels
I have a 72 with the wood grain ranger package the vinyl door panels are worn and when trying to buy replacements for the panel size are to small (27x15). Mine are roughly 32x19 size of the f250 panels but when I call vendors they say it won't fit one vendor said I have f250 doors so they should fit but he is Not sure can anyone help me out shorting this out.
72 F100 XLT ranger 390
- 71PA_Highboy
Re: 72 ranger door panels
Ranger door panels are a 4 piece assembly - Arm rest, decorative panel, BIG trim and steel backing panel.
You need to figure out what you need.... sounds like just the decorative panel (woodgrain and shiny trim) and not the whole thing.
If you DO need the whole thing, you will have to buy the steel panel and BIG trim from someone.... they are not re-popp'd as far as I know...
post a pic and we can probably offer more advice...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
http://img23.imageshack.us/img23/4024/imageomod.jpg
My original is up top the one at the bottom is the (standard size) I don't need door handles or armrest just the vinyl panel itself it did not have a metal panel behind it just the cardboard covered in vinyl
- 71PA_Highboy
Look here:
http://www.fordification.com/library/ma ... ewsIndex=1
hmmm... it may be that the 72 are different than I believed...
Which vendor has 72 Ranger door panels?
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Well that is the problem I am running into I don't see anyone selling ranger panels but apparently the panel is larger than a standard f100. The opening in te door is about 2 inches larger than standard but the measurements are the same as a f250 door panel and when I looked up pictures of a 72 f250 they look like te same size as the ranger panels. I am going to take the risk an order f250 panels.
You might have already seen these, here's some Ranger panels; go to pages 18, 19.
http://npd.dirxion.com/WebProject.asp?B ... flx&from=2#
