Custom gauge cluster
- lifted72
So I had to do some modding to my custom f600 dash gauge cluster, I figured I'd show it off a little.
POLISH EVERYTHING
Re: Custom gauge cluster
What gauges are those? I like the look of them.
- lifted72
Holy hell those are not cheap!
Nevermind. Read their site wrong. Not as expensive as I thought. haha
- Kurt Combs
- Mike R
Where did you get the guage bezel? The big silver thing... I don't know what else to call it
Theeeeeeere ya go!
In Progress:
'67 F250 Custom Cab Camper Special "Cecil"
In Progress:
- lifted72
It's a modified F-600 bezel. I added the the accents or eyelids or whatever, and cut the face panel out and made a new one.
POLISH EVERYTHING
- Mike R
Where did you find it? Was it luck?
Theeeeeeere ya go!
In Progress:
In Progress:
- Hiroshi
lifted72 wrote:So I had to do some modding to my custom f600 dash gauge cluster, I figured I'd show it off a little.
[ Image ]
Nice looking. I have F600 style gauge too, do you know the screws specs used in this gauge? I mean that 8 screws, 4 in the upside and 4 in the downside...
- colnago
I don't know the screw specs, but when I put in an F600 cluster, I was able to use the original screws from my stock cluster.
Joseph
Joseph
- Hiroshi
the thing is...i can't buy new ones here cause they don't have the same size, i think it is differente here (I'm from Brazil).
So i need ...the size of screw...I bought @ ebay #8 x 3/4" with #6 head, but they're slightly smaller
- lifted72
I imagine you can make #6s work.... Do you not have hardware stores in brazil? If you can just find some stainless screws that are close, you can make them work.
POLISH EVERYTHING
- lifted72
Mike R wrote:Where did you find it? Was it luck?
I found the 600 bezel at a swap meet.... it was just a stock f600 bezel, and I built the rest around it.
POLISH EVERYTHING
- Hiroshi
Yes, we have, but i can't find oval head and philips...lifted72 wrote:I imagine you can make #6s work.... Do you not have hardware stores in brazil? If you can just find some stainless screws that are close, you can make them work.
i bought some from an ebay seller, but the size is different, here is the picture...black is original
7mm equals to #6
8,5mm equals to?
