Yea, I have to get out there and start cleaning. So much needs to be put away and thrown away!
- Manny
hfdco4 wrote:Yea, I have to get out there and start cleaning. So much needs to be put away and thrown away!
ROLLER !!!! awesome know the pains of the shop disaster zone.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
It really looks like bomb went off in a junkyard! I hope to get out there tomorrow and start at the back and work to the front.
Got out to the garage today. Still haven't found the spring plate I was looking for. I did find one from the rear spring that I used temporary so I can get this moved!
And this is what the garage looked like just before closing the door this evening.
- popeyes71
Now you have some room to move around! I'm sure that spring plate will show up eventually.
-Popeye-
1971 F-250 4x4 Highboy
Goodness I hope so soon. Now this weekend I am going to fill the front and rear axles with gear oil and then pull the frame out of the garage. Next up is Cab work! Grab the popcorn and watch the show. You will have to decide if it's Drama, Comedy, Horror or successful........LOL.
- cdnwillyg
Paul does your wife know you do housekeeping?
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
Good work! It's always twice as hard to work in a messy garage. Your not gonna know what to do with all that space now
Kyle
Kyle
Believe me I hear about what the garage looks like all the time, yes she is right but it is still tough to hear.cdnwillyg wrote:Paul does your wife know you do housekeeping?
I hope to be able to lay out a bunch of parts and go through what I need, what needs to be junked and what can be passed along to someone else's project.Lone Ranger wrote:Good work! It's always twice as hard to work in a messy garage. Your not gonna know what to do with all that space now
- Manny
Your doing a great job for a small two car garage. That's impressive. That plate is right where you left it! Sorry I know the pain
Time for an update. Worked long hours last week so had Friday off! Here are the pictures to prove I did something.
Moved it over beside the garage and covered it with the tarps that had been covering the cab.
Then I got the Cab into the garage.
The cab survived being outside for the better part of 6 months. Now it is sitting in the garage.
- cdnwillyg
So what is the plan on the cab? Looks pretty good from here!
:drive:Willy
:drive:Willy
