1972 Ford F-250 auxiliary gas tank
Re: 1972 Ford F-250 auxiliary gas tank
I'm looking to replace the Auxiliary tank on my 72 F250, 2wd. The tank which was originally located between the frame and left side of the truck behind the cab. It has a dealer installed fuel access cover. Does anyone have a suggestions for a replacement tank to fit in the original spot as the one removed? I've been looking around but am unsure about which one to pick.
- FLASH 1
Gas Tank might be there, But where is the skid plate ???, where is all the mounting hardware ???, where is all the special brackets that are rivoted to the frame ??? and special brackets that goes from side of the frame to the other & to trans mission cross member ???,, oh yes might be nice to have a tank BUT without all that other items I just mentioned the tank is useless
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
