I have a 1968 F100. 360 with a 3 on the tree + overdrive. When shifting from gear to the next it grinds. Any advice?
Thank you
Transmission grinding.
Re: Transmission grinding.
Welcome to the site.
Grinding gears Usually means the clutch isn't dis engaging enough.
That could be one or more symptoms.
The linkage needs a simple adjustment.
The cab settles down on the front mounts , which will affect the clutch and column shift linkage.
there may be some info , if you go to our home page and look under technical articles .
