Door Panel Speakers
MadMaxetc
Re: Door Panel Speakers
Post by MadMaxetc »
JMcTurnan wrote:I mean to cut straight and the curves around my door panel. If I take a 24"x36" piece and cut it to the door panel. You dont think it would work? What would be the best way to get a clean cut then? Jig saw or band saw doesnt sound right to me lol.
Actualy, that is the correct way to cut it. Just take some bar soap and rub it on the blade a few times trough the cut. This helps the blade shed the Al shavings. Also works well on files for cleaning up the edges.
For the speeker holes, I use a roto-zip type atachment on my dremal and a steel cutting bit. 1 bit does 1 hole as the steel is realy hard on the bit. But if you are doing Al then you should be good to go.
Don't drop the soap!
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
JMcTurnan
Post by JMcTurnan »
Thanks, Madmax. Ill definetly take that advice. I will have to get a dremel tool.
