69 f-100 budget build
- wndsofchng06
Re: 69 f-100 budget build
So now I'm on the fence. Got my new cab mounts, for my new weather stripping, new fenders, rims, and tires.... Which engine do I use? The 4.6 ford v8, rebuild the 240, the 4.3 v6, or the Benz 5cyl diesel. I have all of these at the house, running driving, good engines..... Just when I thought I had a plan.....
- wndsofchng06
I think I've decided to go with the inline 5 turbo diesel. Won't be a heavy hauler, but will get better fuel mileage, allow me to run WVO, and be a good "homeowners" truck.
Nice solid truck!
- wndsofchng06
Got a P/S box for it today. Came out of a 74 ford with 56k miles on it! truck was totalled and the guy was using it for parts on his project.
- wndsofchng06
ordered my transmission off fleaBay today.... can't wait to start mocking everything up in the truck. (fingers crossed, I need some more weekends without rain!)
I will certainly start posting more photos once I actually begin the work.
- Mancar1
Sounds like a interesting project
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- wndsofchng06
Transmission came today!!! YAY
- wndsofchng06
Started working on pulling the front off the truck to replace the fenders and put the new engine in. Found much more rust than planned and had to cut a lot of bolts.
- wndsofchng06
- HIO Silver
I suggest ya start spraying all nuts and bolts with PB Blaster (or equivalent) - even the ones your not even thinking of removing. I'll go as far as preventative measure to remove the nut or bolt, hit it quickly with a wire brush, apply some antiseize, and reinstall... for next time. And there usually is a next time.
- wndsofchng06
Yea I been soaking them with PB Blaster..... Good stuff.
- wndsofchng06
Rest of the nose is off, and got the truck pushed inside.... UGH my back!
- wndsofchng06
Definitely need a new radiator support and driver's side inner fender.... The hood might have to do for now, but it's rough!
- wndsofchng06
- wndsofchng06
Bought a new hood, inner fender, and for support on Saturday. They should arrive Wednesday. I will post photos when they arrive!
