1967 F-100 project
- 67nukeford
Re: 1967 F-100 project
Green sales in Cincinnati hooked me up with the corner parts. Here is the inner support mocked in.
- 67nukeford
had to do a repair to the support that runs across the back of the box.
- 67nukeford
Everything primered and ready for assemly.
- 67nukeford
Inner support welded in, then the outer corner. Came out really nice. Just have to fab up a piece to cover the side marker light.
- 67nukeford
On to the box sides, starting wit the drivers side. So, I attempted to save the rear half of the drivers side. It was pretty pitted on the back side, and the metal was weak in those areas, so I attempted a series of patches. As you can see, it was just a bit much, so, I rolled the dice, and bought the back half box side from LMC. Haven't had a lot of luck with these guys. This wasn't the greatest either, it was going to take some massaging to make it work.
- 67nukeford
Of course, the stamping was right, so, I had to massage the belt line to fit. This was not fun.
- 67nukeford
Original panel cut in half, and new piece fitted.
- 67nukeford
Wanted to install the fuel door, before I welded the bed sides on. Robbed this from a 79. Made a backing plate for it, and marked the hole in the box side.
- 67nukeford
cut out the hole, and then made a mount for the filler spout. This one is from a Dodge chassis cab truck. Cut out the hole in the box floor to fit the filler mount. And, yes, I made the damn cut too big on the back side, so I'll be welding some of that metal back in.
- 67nukeford
Clamped in the fuel door panel and welded it on. Oh, and fix the too-big hole on the back side!
Wow really nice work.
- 67nukeford
After resizing the hole in the box floor/side, I made up a cover for it.
- 67nukeford
prepped, welded, primered
- 67nukeford
also prepped and undercoated the bottom of the cover.
- 67nukeford
finally time to get one of the box sides back on. Undercoated the back sides of the drivers side, and then applied weld through primer.
