My 68 flareside project.
Re: My 68 flareside project.
what did you used to clean up the engine prier to painting?
1967 f100 stepside 300ci I6
1969 f100/600 stepside retro truck -under construction-
1972 longbed trailer
- wickedinhere
I used superclean its the best thing i have found, i have been using it for years. I had to use a small brush on some of the motor where the grime was real thick.
The rest of the parts were just wire wheeled including the tranny.
You can pay more but you cant buy better.
- wickedinhere
I got the motor and tranny in this morning, tranny lined up great and it all went in like butter i couldnt believe how easy it went in.
- 1967AceStroker
Man thats really lookin' good with the motor in there. With all the new black and blue paint it looks so good.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
Lousiana eh? What part?
What link setup are you running?
- wickedinhere
Thanks for the comments. I didnt do a link setup on the rear i kept the leaf springs and did a axle flip kit with a djm shackle and hanger kit. I wanted to do it a little different so i kept the rear leafs and ibeams. It just doensnt seem right to have an old ford without ibeams. LOL. I am from southwest louisiana.
- wickedinhere
I got the header,carb and intake on this morning checking for clearance and making sure there are no problems it all looks good.
MORE TO COME.
MORE TO COME.
hedman headers?
- wickedinhere
- wickedinhere
Well i got the intake and header all torqued down the throttle and choke are hooked up the carb is bolted down. I ordered my gauges for my f600 cluster and i went ahead and upgraded to a 130 amp one wire alt i figured with electric fuel pump and fan plus a stereo the stock alt wasnt gonna cut it.
- wickedinhere
Getting it done slowly but surely here are a few picks of the carb linkages i know alot of people ask about the carb linkages. In case someone says the carb is on wrong i have the offy c intake not the dual plane intake.
- 72stepside
If you didn't strip and paint those Hedmans, the factory finish will burn right off. Again, don't ask me how I know.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
- wickedinhere
Well i started getting my clutch z-bar assembly fixed up and noticed that the clutch rod is worn more than i thought so i looked under the dash to see how worn the other end is and its worse. Then i realized that where the rod hooks to the pedal is really worn out so i pulled the pedal assembly to weld up the gap were the rod wore it down. I have it out and looking at it i see where the metal bushing are all loose and cracked. I gave mustang steve
a call and ordered his ball bearing pedal kit so it should be here in a few days. Today is the day i realized that i will have this truck till i die since i am spending so much money on it, it will probably be my ride to the graveyard. I got my f-600 cluster in and its gonna look good with my gauges.
- wickedinhere
