New Engine for The "Speed Bump"!
FoPAR
Re: New Engine for The "Speed Bump"!
Post by FoPAR »
Enjoying the project and all the fab work :thup:
"FoPar" because I love Fords and Mopars so just call me FoPar... :D
Manny
Post by Manny »
That thing looks like it'll run..... What you looking for on you ET slip.
SVT522
Post by SVT522 »
I'm hoping it will run mid 11s or quicker. I'm trying to keep weight out of it...light makes might! It weighed 3650 with a Cleveland and a C6, I'm hoping an aluminum headed big block will get me close to that.
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
Manny
Post by Manny »
SVT522 wrote:I'm hoping it will run mid 11s or quicker. I'm trying to keep weight out of it...light makes might! It weighted 3650 with a Cleveland and a C6, I'm hoping an aluminum headed big block will get me close to that.
Nice for a fullsize truck should be good. :thup:
SVT522
Post by SVT522 »
Finally got back to work on the "Speed Bump" yesterday. My daughter and her fiance' bought a house and I've been helping them move the last few weeks. I'm fabricating the exhaust with a Flowmaster 3-inch dual exhaust kit with mandrel bends and I'm using Dynomax Race Bullet Mufflers on it. The bullets are definitely free flowing and that's an entire orange sitting in the end for size comparison.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
SVT522
Post by SVT522 »
I worked on the exhaust some more this weekend. I started with the Flowmaster 3-inch U-Fit dual exhaust kit. It came with a 2.5-inch H pipe.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
SVT522
Post by SVT522 »
I made a jig out of 2 x 4s and a piece of plywood to make sure that the tailpipes were in the same location on both sides and clamped it to the frame with a C-clamp. I used ratchet straps to hold the tailpipe to the jig. I then measured and cut the over axle tubing to connect the mufflers and tail pipes with out hitting anything. I then tack welded the assembly then removed it to finish welding. The driver's side is done...passenger side next weekend. I'm going to run stainless tips and they'll end up a 1/2 inch below the bumper.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
SVT522
Post by SVT522 »
I finished the exhaust yesterday and painted it with high temp ceramic header paint today.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
SVT522
Post by SVT522 »
I bought a new '95 Mustang 3G alternator from DB Electrical and mounted it today. It puts out 130 amps max and 70 amps at idle.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
Looks great! Was this the one you got? http://www.dbelectrical.com/p-4110-new- ... -7771.aspx
SVT522
Post by SVT522 »
Randy,
This is the one I got:
http://www.ebay.com/itm/NEW-FORD-MUSTAN ... 3437987938
At $87.70 and free shipping it was the best deal I could find! I had to put a thin shim behind the v-belt pulley to keep it from bottoming against the case when tightened. The mounting points are in the same place as the stock 60 amp and it was a virtual bolt in. The only difference is it takes a metric bolt where the adjustment ear is. IMHO it looks much better with the internal fans. Also, I'm going to be running a Lincoln Mark VIII 2-speed electric fan, electric fuel pump, and multi-spark ignition so I don't want issues with the alternator keeping up when I'm sitting in traffic.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
Ok, thanks! Got that one bookmarked for later reference.
SVT522
Post by SVT522 »
I finished everything on my exhaust except for the tips and where they exit. I'm not sure whether to go straight out the back or angle them out at a 45 degree angle behind the rear tires...I could also do a 90. The U-Fit kit will let me do any of the three. Any opinions on where the tips should exit? I plan on using slant cut stainless tips with 3-inch inlets and 3.5-inch outlets.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
SVT522
Post by SVT522 »
I ordered a '69 Mustang 20 gallon fuel tank kit today. I'm going to install it at the rear of the frame like Bobbyford and some others have done.
SVT522
1996 SVT Cobra #522
1987 F-250 4X4
Kraig
Post by Kraig »
Straight out the back......
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
