Pictures while using frequent flyer miles
No tech discussion, please
NM5K
Re: Pictures while using frequent flyer miles
Post by NM5K »
PHNL... I've done that one a few times on the sim. Same runway too. The buildings off in the distance
look about the same on the sim..
What do those C-17's usually cruise at? Kinda surprised you would be much slower than any other jet..
With the 737's I usually run, I tend to cruise at mach .78-79 or so most of the time, assuming the
upper 30K flight levels.. I've got a 900 I've got rigged up now as a BBJ3. It's the biggest and
baddest of my artificial 737 fleet. Has all the extras, including the [censored] sinks. :lol:
I made a video using it going into Playa de Oro a few months back. "Mexico on the Pacific coast. Visual landing..
I actually flew it from the left seat, but decided to make the video from the right seat, being as I don't show
that side too often. It's fully operational from that side. Kind of shows the FO's perspective and terror when landing
at the mercy of me running things from the left seat.. :evil: :lol:
It probably looks better if you watch from youtube as it's 720p HD and you can go full screen.
http://www.youtube.com/watch?v=jHGuXp6n ... e=youtu.be[/video]
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
adrianspeeder
Post by adrianspeeder »
NM5K wrote:What do those C-17's usually cruise at? Kinda surprised you would be much slower than any other jet..
Normal at .72, and I've seen .77, but that was for a medivac and our fuel burn was crazy at something like 20k per hour. Big block motors, big fat body, not real efficient on the high end.
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
NM5K
Post by NM5K »
I guess they would burn the fuel if you were humping it with a big load.
Some of the jets will have an "economy" speed usually at high altitude.
The Learjets were one I can recall that did.. You could run mach .77-78 or so,
but economy cruise was mach .74, and usually well above FL400.
With the 737NG's, I usually go with the recommended FMC speed suggested.
Which is usually mach .78-79 range in the upper 30k range.
But will vary a bit on the cost index that you punch in. The higher the cost index,
the higher the speeds overall, including the IAS speeds during climb and descent.
Actually, the IAS speeds probably change more than the cruise mach speed from what
I see using the various numbers. When I'm playing Southwest I'm using running
a CI of about 36 or so.. But with my private planes, I might bump up a tad. Say 40-45.
With a CI of 36 in a 737-700, you will usually climb out a bit above 290 knots.
With a CI of 45, you might be a tad over 300 knots. But that will depend on the model,
with the 800-900's generally running a bit faster than say a 600-700 with a certain cost index.
adrianspeeder
Trip 017, Winter 2019, Florida
323 - Looks warm down there for a trip in the winter time.
324 - Lifestyles of the rich and famous?
325 – Southwest Florida International Airport
326 - Hooked up with a splash of gas.
327 - So just got two little trucks worth of gas, didn't need a whole lot at all. When I went into the terminal to sign for the fuel card, I saw a sign that had a full rewards program list. 300 gallons for a key ring, 500 for a hat, ect. I asked what does 5700 gallons get me? Shirts for the whole crew apparently.
328 - Pile of private jets including a 737. Someone's got money.
329 - Too hot down here. I want to get back to sub freezin' Delaware.
330 - Square neighborhood.
331 - First time I've ever flown over the Bay Bridge Tunnel in the daytime that connects lower DelMarVa.
332 – Hi friends.
adrianspeeder
Trip 018, Winter 2014, Panama
333 – Powered up for preflight to head to Panama with spare parts and tools for a C5 flap change.
334/341 – It’s a beautiful cold day, but do we have clearance? Nope. So, we sit until the alert burns. Well, I’ll just take nice pictures.
342 – Reset to fly in 24 hours when the paperwork is square. In the middle of a snow storm, so delayed again to the place is plowed. Had to bust out the cold weather book to put diesel fired heaters in the oil servicing doors to get them to crank.
343 - Who do you think you are? Taylor Swift? Thanks for the cold weather help friend!
344 - Panama was friggin hot and not sure what was sweatin' more. Me or the jet.
345 - Goin' from 10 to 100 in a few hours is a fun time. I like the cold much better.
346 - First time I've ever seen an operational 727. Loud SOB!
347 - Back to the friendly cold on a snowy DelMarVa day.
Last edited by adrianspeeder on Mon Jul 12, 2021 11:35 am, edited 3 times in total.
NM5K
Post by NM5K »
Had a Kalitta cargo 727 fly over me a couple of nights or so ago. It was fairly late, and I assumed it was a
straggling Southwest jet from the west coast or sumtin.. But looked on Flightaware and it was a Kalitta cargo
727. They also had a biz jet that was running along with it. Both went on to the Denver area later that night.
I flew on a 727 once back in Nov 1969. It was a baby doo-doo green Braniff, and flew from Kansas City downtown
to the brand new Houston Intercontinental. We stopped in OKC on the way as I recall. That was back when
Braniff painted all their planes the different colors.. Green, orange, yellow, brown, etc..
Made another video the other day. Going into Toncontin "MHTG" with the 900. But is only a quick outside view of
the appx 120 degree turn to final and landing.. Was doing RNAV 02 from the south. Plopped it down right on the
numbers. :)
http://www.youtube.com/watch?v=PjGG3cm4 ... e=youtu.be[/video]
adrianspeeder
How was it? I have never seen a 727 fly before. Don't expect to ride on one either ever.
Adrianspeeder
NM5K
Post by NM5K »
They were fairly comfortable. I remember when the pilot landed at KIAH, he really greased it.
So smooth you couldn't hardly tell that the wheels hit the pavement. Smoother than most 737
landings I've been on. With the newer 737's, they use gear strut and wheel spin sensors for
spoiler deploy and autobrakes if used, so it's generally considered bad practice to land a 737
too smooth. Back in the day, the 727's ran pretty fast too.. usually mach .80 or faster. I think
up to about .86 or so, but like the planes you fly, they would really start sucking the fuel at the
higher speeds, so mach .80-.82 was more common for economy.
adrianspeeder
Same for us. Plant that girl down and whichever weight on wheels switch closes first is the winner that drives all 8 spoilers full up.
Adrianspeeder
adrianspeeder
Trip 019, Winter 2014, United Arab Emerates
348/349 - First time I've seen the Jersey Shore look nice.
350 - Funny lookin' trees in Turkey.
351/352 – Night shift preflight and launch.
353 – Cold jet fuel + humid hot desert. Stay frosty.
354 - Hi friends.
355/356/357 - Ready to load, let’s get 'er done.
358 - Never quite get the timing right to not be staring at and chasin' the sun west every trip home.
359 - Well this isn't home. At the 11th hour we had a weather divert to New Hampshire.
360/361/362 - Next day clear and some good views of Massachusetts.
adrianspeeder
Trip 020, Winter 2014, Uganda
001 – One with flap problems and the other with a slat stuck in transit? We’ll take an intersection departure from Charley please.
002 - Big kids Spanish juice box.
003/004/005 – Beautiful Spanish morning.
006 – Diplomatic clearance into Africa didn’t come through, so shut ‘er down, and head back to the hotel.
007 - Shoulda paid more attention in Spanish class.
008 – Your lips taste like sangria.
009 – Big big fan of dinner.
010 – Pub Los Arcos in Rota Spain
http://youtu.be/v-0OQxEAaqc
[youtube]v-0OQxEAaqc[/youtube]
011 – After some paperwork delays, my first African sunrise.
012 - African Grand Canyon.
013 – P&W power.
014 – African views.
015 - African super dirt road highway.
016 - African metropolis.
017/23 – So the wikipedia tells me this airport was famous for the divert of a hijacked jet, and Israelis comin' in to get all their hostages back. Should be a good time...
023/024/025 Legit hotel in Africa.
adrianspeeder
026/027 Not too bad.
028/29 - Wake up the next mornin' and this is outside my hotel room.
030 – You ain’t at a legit African airport without an old dead L-1011 sitting on flat tires.
031 – Pilot, copilot, one load, and me head in the next day to two engine taxi the airplane to the main terminal to pump a **** ton of gas that they weren’t able to truck out the day before.
032 - Little hoses are my favorite for pumping gas for hours instead of minutes.
033 – West Nile Virus
034 – Ready to launch. These bugs ain’t no joke, we gotta go!
035/41 – We’ve left the bugs behind for dodging some monster African storms. I bless the rains down in Africa.
042/046 - Rollin' into Kenya.
047 - Hey look what's sittin' in the dirt in Kenya. Another dead L-1011.
048 - Friendliest guys I've ever met in Kenya that were around the jet. Prolly had my picture taken with every one of 'em and on all their facebook pages.
049 – Nairobi Kenya, Feb 2014. For the first time on this African safari trip, I had to do a little bit of work. The airport authority wouldn't let us use thrust reversers to back away from the terminal where our parking spot was, and insisted we get a pushback. Not a thing to do with noise, but to snag that $5k pushback fee. Next, the rattiest Uke rolls out without a towbar. Most commercial airports have a 767 or DC-10 bar that works with our nose gear no problems, so I thought for $5k, this was a sham.
“Where is your towbar.”
“Sir it is broken!”
“So can we back out ourselves?”
“Sir, you must have a towbar!”
Not looking to get in an argument, and because we actually did bring a towbar on this mission, let’s just play along. I’ve also found most commercial airports don't like you hanging out on the taxiway while we go through our convoluted engine start checklists compared to civilian world with fast as possible to make money engine start procedures. The A code agreed, and we decided to go with the engine runnin' pushback. I stood ground through the start sequence because it’ll take a minute for the loads to roll the towbar around some rolling stock and down the ramp.
“Is this lugging and chugging crate even going to have the ummph to move us?”
“Sir it will go!”
“Let’s roll!”
To his credit, the driver slowly got us most of the way out of parking, and %100 blocking the taxiway. I brought the show to a stop, had the pilot set brakes, and motion the driver to back up to unload the weight of the jet on the towbar. His frantic pulling on the shifter wasn’t working, so the driver shut down the motor. Finally went to neutral, but then it won't crank. “So there I was,” with an engine running C-17, blocking 2 or 3 other jets now, pinned tight to a dead Uke, with the pilots askin',
“Chief, what’s goin' on down there? We gotta go!"
Yelled at the guy to get on the radio for another tractor so we could pull it back enough to yank the pin, and we’ll back ourselves away from this mess. Minutes later, the littlest 3 cylinder diesel New Holland baggage cart tug makes it's way over. I knew she had no chance of budging a 50 ton Uke, but they tried anyway.
“Screw this.”
Got my toolbox from the jet, and with some resentment they let me pull the two batteries from the New Holland and wire them in series for the 24v Uke. Fired that joker up, backed him a hair, pulled the pin, undid the bar for the loadmasters to winch up the ramp. Came back to the front to reconnect the nose wheel steering, pull the pins, and let’s wrap this checklist up. By that time, I noticed the Uke had driven away before giving the batteries back to the New Holland. Just don’t stall that unit. Ooops, looks like they did. Oh well, had just enough room to steer to the left around 'em. Onward to the next stop!
050 – Embassy rep traded a patch for a coin.
adrianspeeder
Great job! Your Master of Bumpology got another star added!
adrianspeeder
051/052/053 – Leaving Kenya for Burkina Faso.
055/056/057 - Kickin' back watchin' Africa fly by.
058 – Why is everything on fire?
059 - Another African highway.
061 - Charlie! The meadow is on fire!
062/063 - Was hopin' to see some wildlife. Like a giraffe or somethin'.
064 - Got the hookup of some local beer and cokes for 5 cents each.
065 - The great debate of how to sleep on the jet. I prefer the crew rest section floor between the CRACM seat and left avionics rack. Lots of loadmasters like the ladder setup with a hammock.
066/067/068 - Normally sitting behind the copilot or pilot seats on takeoff, we'll watch for birds and such. With this brush runnin' right up to the runway we were ready to call out for lions...
069 – By the last stop, look more fire...
070 – Prepare for landing.
071 - Last stop. Pure nothing around. This has been a great trip, but now we need a **** ton of gas to get home. From a tiny hose. Dammit.
072 - 200k lbs please. Dammit. Only had enough ummph to fill one tank at a time.
073 – Slowest refuel ever.
074 – Hero crew shot.
075 – Finally unloaded, fueled, ready for a long flight home. Not going to miss the number of bugs with West Nile Virus on this one. Otherwise a good trip.
