An alternative to Metal Ready
General Discussion Topic Archives
spartman
Post by spartman »
Found out that the main ingredient in Metal Ready is Phosporic Acid.
If all you want to do is remove the rust you can either buy it from a school chemical supplier, ebay, or get a concrete cleaner.
If you have a home depot near by simply pickup the Pre-Cast Concrete Cleaner product made by Miracle Sealants.
The stuff from Home depot is acutally a little stronger than the Metal Ready.
Just thought I would throw this out and see what came back.
steveheer
re: An alternative to Metal Ready
Post by steveheer »
Yea, and probably 1/3 the price!! :lol:
Steve
69 F100 300I6
67 Mustang fb FE 431ci
72 Gran Torino Sport 351W
91 Bronco 351
ladz
Post by ladz »
por-15 is the same as industrial steel sealer, witch you can by at your local paint store it is also used on bridges to seal ! It is made the same catalyst and composites as por -15. After the bridge is prepped and painted the density is taken to see if there is coated to spec this is called hang time most steel workers know about this stuff !O and is half the cost at the local paint store!
binder56jd
Post by binder56jd »
thanks for those heads up tips :thup: jd
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
spartman
Post by spartman »
Thanks for the info guys!
If I were to try and get this steel sealer what kind of paint store would I need to visit?
xxxtina63
Post by xxxtina63 »
Cool. So this stuff will actually eat off the rust? I suppose you have to keep an eye on it or do it in several stages. If I recall phosphoric acid will also eat through the metal if left on too long. Does this sound right? Has anyone tried it? Does it work well?
spartman
Post by spartman »
It will like all acids eat the metal completely.
The big thing with the phosporic does it a lot slower and safer than the hydrocloric or sulphuric acid.
I bought a bottle of stuff called rust eater at my local TSC and am trying it on an old rusty carb from a tractor.
The carb is all cast iron and was badly rusted inside and it seems to be working quite well.
mrsnicks
Post by mrsnicks »
Anyone done a price comparison on the steel sealer? Is it UV resistant? Colors?
Patrick
Chevrolet
Can Hear Every Valve Rattle on Long Extended Trips
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
http://www.fordification.com/galleries/ ... ?cat=10336
flyboy2610
Post by flyboy2610 »
Are you supposed to wash it off before you apply the Por-15? :?
I thought after the Marine clean stage the metal wasn't suposed to be touched?
Red Green
you'd better be right.
spartman
Post by spartman »
You need to wash off the marine clean when you are done.
Otherwise it will keep "cleaning" the metal.
flyboy2610
Yeah, I understand that the Marine clean needs to be washed off, but I geuess I should have clarified my question.
Does the Metal Ready need to be washed off, too? I can't find anything on the label about that. Or does the first application of Por-15 neutralize the Metal Ready?
Red Green
spartman
Post by spartman »
The metal ready does need to be washed off also.
Sorry bout that had a brain fart.
If left on the acid in the Metal ready will possibly eat all of the metal.
Also with metal ready it will leave a powdery residue that the POR cannot bond to.
flyboy2610
Ooops!
It was on the label. I missed it. My bad.
:oops: :oops: :oops: :oops: :oops:
Red Green
spartman
Post by spartman »
I guess that makes us even then.
