bonus from my parts truck
General Discussion Topic Archives
72hiboy4x4
Post by 72hiboy4x4 »
after many (many) months of messing around, I finally got the 390 engine pulled from my '65 parts truck.
well I know it had a holley carb on it, but when I pulled the air cleaner off, it turned out to be a 4BBL carb, and after I looked it over, the intake is an 'S' code manifold!
so I'm a happy camper now. and I want to send a special thanks to DarrelM and his friend for donating this truck to my project!
on a side note, I found a '80 F-250 4x4 that just needs one of the engines I have laying around here for CHEEP! supposed nice body and interior, complete minus engine. and I already have an '80 for parts here! can't beat that with a stick! I'll see it tomorrow and get pics if I get it.
i love making good deals like that work
mrsnicks
Post by mrsnicks »
Okay.. not into the whole FE thing.. signifcance of the "S" code manifold?
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Badgt04
Post by Badgt04 »
mrsnicks wrote:Okay.. not into the whole FE thing.. signifcance of the "S" code manifold?
Patrick
I am interested as well...I may look into my Intake in further detail
^ Where would the code be found
1973 Ford F-100
68F250
re: bonus from my parts truck
Post by 68F250 »
Lots of folklore on the 4V "S" intakes. There are several versions of it, early S, later S, big S, little S...
Personally I think the early big S is the better one.
Guess we'll find out with the network54 intake tests.
Barry
rjewkes
Post by rjewkes »
Here you go. Badgt04
fuelly.com
mrsnicks
Post by mrsnicks »
Umm.. but what does the S signify? What makes is so Special?
Patrick
Chevrolet
Badgt04
Post by Badgt04 »
rjewkes, so it is an S-code intake that I have?
Does this mean I can retire at the age of 19 ? lol !!!!
1973 Ford F-100
jcwillis
The S Intake
Post by jcwillis »
Hi Fellas,
The S intake is associated with the S Code engine in 67-69 Mustangs and Cougars and other Fords / Mercurys (earlier for these). Next to the 428, it is a big deal in the Mustang / Cougar crowd because it is a big block. The S Code engine was a 390 cid 4V rated at about 320HP. The S Code engine is also referred to as a 390GT. A Holley was used for carburetion until 1969 when an Autolite carb was used.
Jim
68F250
Post by 68F250 »
4V S intakes were used on more than just the S code engines, also used on the 410 and 428. I don't think the S on the intake means the same as the S for the engine code or that the two go together. There were many S code engines with T intakes.
Barry
jcwillis
S Intake Manifold
Post by jcwillis »
Hi Barry,
Agree that S intakes may have been used in other applications. Never said that the intake was only used in a certain application.
Was only trying to point out the general association that many folks make, whether right or wrong, concerning the S intake.
Jim
68F250 wrote:4V S intakes were used on more than just the S code engines, also used on the 410 and 428. I don't think the S on the intake means the same as the S for the engine code or that the two go together. There were many S code engines with T intakes.
68F250
Post by 68F250 »
Hi Jim, I wasn't trying to be argumentative. Sometimes it's hard to write the tone of voice.
More info, there were also 2V S and T intakes.
Have heard that the first S intakes were designed for the Tbird but then used across the board. I don't put much faith in that, just spreading the word.
Barry
rjewkes
Post by rjewkes »
doesn't it have something to do with the runners? When it comes to an intake. On the engine does this signify HIPO?
fuelly.com
68F250
Post by 68F250 »
Yes, the runners on the T intake are like the old '58-'65 design except they neck down to match the smaller head ports that were standard on most '66 and later heads. The runners on the S are more uniform, does not signify HIPO. Here's a pic of a mid '70's T (with EGR) and a mid '60's S for comparison. They both have the same size ports at the head flange.
Barry
