why dosent my drivers side door lock????
my friends and my truck drivers side door dose not lock . i shut the doo and the pin goes up and when i get the key and try to lock it it dosent want to turn
re: why dosent my drivers side door lock????
Are you sure you have the right key?
The door has to be locked with the key...just pushing the button down and closing the door will unlock it, this was a factory design to keep you from locking your keys in your truck. As to why it's not working, you might want to pop off the door panel and take a look at the mechanism and make sure it's not bent or broken, and maybe lube it up a bit.
- jor
Here's a few photos of the inside. In the #1 photo, the blue arrow points to the lock mechanism and the red one to the the button mechanism. The other two show a closer view of each.
jor
jor
hey thanks alot i appreciate it alot thanks again.
Mine will not lock unless I lock it with the key. If I push down the lock on the inside of the door and shut the door it pops up and is not locked but it will still let me lock it with a key.
I guess that it the saftey mechanism that was talked about, if so it sounds like mine is working.
Not sure why your key won't lock it.
Andy
1969 F100 300i
3 on the TREE
1969 F100 300i
3 on the TREE
maybe something aint lined up right or something cuz when i try to lock my driver side door it wont wanna turn till i push it to the unlock position and push it back ive tried to fix it but its like man i got other stuff to do so i go eat some twinkies
- rjewkes
probably locking up inside the mechanism. You may need new lock cylinders. What about your key? Is it worn? The edges should be sharp and pointy.
If the key is worn take your passenger side lock cylinder to A good/reputible locksmith(not walmarts) and not any hardware store.
The locksmith will have a book with key codes that tell the diferent hieghts of the grooves.
Your cylinder will have this code printed or stamped/forged in it and your pass is the best one.
If it is not there or unreadable they can properly dissaasemble and reasemble it.
And make a good key. Mine ran 15.00 for them to do this. Butt it will be more if they have to dissamble it.
fuelly.com
fuelly.com
