question about my 1970 trannie options
schmidt2169
Post by schmidt2169 »
I have a 1970 F100 2 wheel drive with a 302. It currently has a 4 speed with granny low, but i was hoping to find a 5 or even 6 speed transmission. I was just wondering what my options are and where i could find a 5 or 6 speed. Thanks.
for a small block that will be hard to find. maybe if you had a fe you could get one from a f600 or something of that size. if it would fit in your truck.
GT-Racer
Post by GT-Racer »
You can use a five speed from a newer model truck or mustang but the arent the best if you are gonna make much power.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
binder56jd
re: question about my 1970 trannie options
Post by binder56jd »
here's a link- scroll down to trans
http://www.jamesduff.com/broncoII/v8conversion.html
now serving #235
customcrewcab
Post by customcrewcab »
what state are you in? i have a good 5 speed and belhousing forsale.
you can have the yoke lakewood bellhousing and shifter for 500 plus shipping. its been rebuilt and has a new gearset. its the same as a world class t-5. i even have a centerforce clutch. just the clutch not the pressure plate. i need a fine spine for the viper spec 6 speed. i think fisrt gear is 3.25 and the overdrive in .5 not the .86.
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
