Clutch-head screw driver or bit
Anyone got a source for these? Even the Snap-On guy doesn't have them, though he can order it. Thinking I'm going to have to grind down a regular screwdriver to fit.
Former owner of 70 LB SportCustom and a 71 SB SportCustom. Looking for a replacement bump!
- Rockcrusher
Re: Clutch-head screw driver or bit
Try TrueValue if they're in your neighborhood1970sportcustom wrote:Anyone got a source for these? Even the Snap-On guy doesn't have them, though he can order it. Thinking I'm going to have to grind down a regular screwdriver to fit.
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
If I can find one, I'll give them a call. There's 6 of them holding a metering block on. I have them on, I use a small sized torx head screwdriver temporary. I need to get some loctite type sealant on these and the screws that hold the base to the body.
Necessity is always the mother of invention...I've found myself needing one of those several times, and ended up just grinding down a worn-out screwdriver and using that.
