New Brazilian info sheet for '70 F100 posted
I got my hands on a two-sided information sheet for the 1970 Brazilian F100. This sheet has been added to the Factory Lit & Advertising page, via the following link:
http://www.fordification.com/lit/70braz ... ochure.htm
Anyone here any good at accurately translating Portuguese? The online translators are worthless for this. I don't want to just get the gist of what's been said, I want an accurate word-by-word translation. If anyone can help out, please let me know.
- 68F250
re: New Brazilian info sheet for '70 F100 posted
Cool find Keith!
But how do you know it's a '70? Their models lagged ours by a number of years. Plus it has the 2.3L Lima engine which wasn't into production until '74. That same engine was later manufactured in Brazil btw.
Barry
Hmmm....yes, you're right. I guess I don't know for sure, other than going by how the info sheet was advertised for sale...and of course the grille, but as you stated that's not necessarily a good indicator for the Brazilian trucks....and there's no date mentioned on the sheet. Oh well. I had to classify it somehow, and until I can get some other info I'll just use 1970 as the print date. However, I think I will add a little disclaimer on that page stating that it might not be for the '70 models.
- 68F250
Good deal! Earliest it could be is '74 because the 2.3L didn't exist before that.
Hey don't we have a member or two from Brazil?
Barry
- Clarko
A 4-cyl F-100?
Damn it must barely move even with the 5.38 gears.
It may not be a Lima 4-cyl but something with just the same displacement. Ford makes a 2.3 currently that is not a Lima engine.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
- 68F250
Yes, but it has the same bore and stroke and is in the right time frame of the mid-'70s.
It's an export version with the low 7.8:1 cr. Thing I don't understand is the high hp and torque figures. Doing a conversion says 97.6 hp and 122 torque.
For comparison, the '75 domestic version had 8.2:1 cr and put out 87 hp with 114 torque. Even the '76 version with 9.0:1 cr only put out 92 hp with 121 torque.
Just for fun, here's a '74 from Brazil with a turbo diesel:
http://produto.mercadolivre.com.br/MLB- ... diesel-_JM
For V8's they still used the Y-block!
http://produto.mercadolivre.com.br/MLB- ... ecavel-_JM
Barry
- mk
Very interesting. Don't see those 16" five lug wheels very often here, either.
mike
mike
Always drink upstream from the herd...
~Will Rogers
Mercury truck ID thread:
http://www.fordification.com/forum/view ... =2&t=35331
Ford truck model history:
http://www.fordification.com/forum/view ... =2&t=37394
Using dentside fender liners:
http://fordification.com/forum/viewtopi ... =7&t=35675
Matchbox diecast bumps:
http://www.fordification.com/forum/view ... =2&t=45618
~Will Rogers
- 68F250
Yeah, click on 'Ford' at the top to see some interesting vehicles.
I want one of these Rurals:
http://produto.mercadolivre.com.br/MLB-46103822-_JM
Barry
- mrung0wa
Now just what, in Tarnation are we talkin' about?
The OHC 2.3L (Engineered in Deutschland) or the Pushrod (High Swirl Combustion Chamber) 2.3L .
You know the one based on the little old I6?
Lawrence
Lawrence
- Clarko
- mrung0wa
Whoa...
Actually, I was refering to the Block.
I owned an 85 MERCURY Toe-spaz and I'm pretty familiar with that 2.3L HSC.
That Block was concieved from their "Small Block" Inline 6. They pretty much just cut the last 2 cylinders off!
It wouldn't be unorthodox to assume that possibility.
Both FORD and Chevy did just that to their "small Block"V8's to achieve their 3.8L V6's.
I'm not sure if Buick did the same thing w/their 231 though.
Lawrence
Lawrence
- Clarko
- Dropped 68
Some good finds Barry! I dig that rural too, lot's of possibilities.
Charles
http://www.fordification.com/galleries/ ... ?cat=10451
http://s111.photobucket.com/albums/n146 ... =#imgAnch1
Build, Destroy, Rebuild!
