3 wire distributors
splavin90
3 wire distributors
Post by splavin90 »
i have a 3 wire distributor, how to i hook it up to my coil?
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
heep70
Post by heep70 »
Where did you get the three wire disty from?
Greg
1971 F250 "Highboy". SOLD to "Highboy_Firefighter_71"
2000 Subaru Outback limited.
2000 F250 4X4 PSD SuperDuty Crew.
2010 Polaris 800RMK Dragon 155"
2013 Polaris Pro 800 RMK 163"
1980 Built Toyota "Trail Rig".
My last 1971 "Highboy" pics
splavin90
Post by splavin90 »
off an 81
kid
Post by kid »
Not without the rest of the 81's Dura Spark system.
splavin90
Post by splavin90 »
so what are my options?
i really think that i can get it to work without the rest of the duraspark system. i just don't know what wire to hook up to my coil.
gonzalo medina
Post by gonzalo medina »
You could get a duraspark harness from painless wiring. I know also msd sell duraspark compatible parts as well...hope that helps
splavin90
Post by splavin90 »
awesome, thanks gonzalo medina
i think i might do that :D 8) :D
kid
Post by kid »
Duraspark is a Hall Effect amplification and pickup system. The Hall effect pickup in the Duraspark dist. is too weak to control the coil. That is what the external module does. It amplifies the signal and fires the coil.
The module has 3 wires for the dist. Power in, Ground and Signal. Then the module has the truck interface connector which is 3 or 4 wires depending on model and year. power in(ignition on), Ground, Coil feed and optional tach which later became early computer tach input.
68F250
Post by 68F250 »
The three wires only supply the timing signal to the ignition module. Actually two are the signal, orange (+) and violet (-), the black one is ground.
You can hook it up to a Duraspark or any aftermarket ignition module. If you go aftermarket I suggest a MSD6, they make an adapter harness so everything plugs in.
Barry
kid
Post by kid »
Yes Orange (+) is power to us Ford techs. I was working for Ford when the Duraspark system came out and I was one of two that went to class the first week.
