Correct tire size for F250
4x4 & Off-road Forum Archives
Moderator: Doug Comer
F250MudPatrol
Post by F250MudPatrol »
I want the biggest possible bad boy mudders for my 1971 F-250.
Dana 60 front and rear.
Dana 24 T-case.
3.73 gear ratio.
3" body lift.
3" suspension lift.
What would you guys/gals suggest? Size? Brand? Style?
The truth shall set you free.
heep70
re: Correct tire size for F250
Post by heep70 »
54" Boggers 8)
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
heep70
Post by heep70 »
If you go real tall your gearing (HP) is going to suffer. I ran 39" mickeys on another Ford and ended up regearing it with 4.56 to get HP back where it needed to be.
I also run 35" on my Toyota with 5.29 gears and the speedo is still under by 4MPH. Kills me going up highway hills.
Greg
averagef250
Post by averagef250 »
If you really have 6"s over stock you should clear 40"s or so with not much cutting.
What you are doing with the truck sure has more impact on what tires to recommend than how big you can fit. I like BFG muds for the street and mild offroad or boggers for offroad only.
I would suggest 31" tires to go with your 3.73 gears.
Wes
Post by Wes »
My 67 came w/ 4.56 r&p and 30 9.50 16.5, lets just say it was no speed machine, I want to go 35's w/ the 4.56's. May be 37's I think they'll clear the stock High boy suspension.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
heep70
Post by heep70 »
35" is pushing it for clearence with the stock suspension. They will rub if you bend it up. I run 33" on my Highboy.
Greg
