shave drip rail
shave drip rail
has abody out there shave off the drip rail around the roof. I have started cutting on mine. no going back now. but was curcious of any tricks or ideasa to patch up the roof etc. Im just useing a cutting wheel on a grinder
open for ideas
chris
open for ideas
chris
re: shave drip rail
i did. make as close a cut as you can, remember, you can grind more off, but once you go to far, your in a world of mess. when welding it back together, make short bead runs, skip around a bunch, spread out the heat, that will cause less heat distortion. grind and weld, grind and weld, grind and weld. about all there is to it.
word to the wise, DO NOT LET IT GET WET until after you have paint on it, you do not want it rusting out from the inside. do not ask how i know.
re: shave drip rail
finally got the rail cut off, now just have to weld on. do u think a gasless welder would work or would it not get hot enogh, and just fall of. i have excess to a gas but dont really want to tow it cuz i have front end off
chris
68 f100
chris
68 f100
- 1968Ranger
re: shave drip rail
Id like to see a picture of one without a driprail????
- shrektruck
re: shave drip rail
FoMoCo shaved the driprails on his stepside. His truck was project of the week a couple weeks ago.
I looked but didn't find the closeups of the driprail area.
FoMoCo?
FoMoCo?
re: shave drip rail
hope to have pictures up soon, i saw foMoCo truck and it looks really nice , i like the smooth look of a clean roof
chris
chris
- FoMoCo
re: shave drip rail
Check this out. I'm no bodyman by far, but am happy with the results. Work careful and slow.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- 1968Ranger
re: shave drip rail
Nick
I like it. Get a picture from the front of the vehicle if you can/
Down the side that is.
Thanks
Thanks
re: shave drip rail
That looks great! I have never thought of doing that! Great job FOMOCO!
You may not claim to be a bodyman but I have seen a few make a real good living that arent as good!
FORD BUILT EM TUFF WE BUILD EM BETTER!!
- MAK
re: shave drip rail
Great work!
- FoMoCo
re: shave drip rail
1968 Ranger:
Here's the olny frontal pic I have at this time.
The paint is PPG Concept, Ford code Z1. I painted my 67 in the garage this past winter break.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
re: shave drip rail
I'm going to be doing something like that on my truck....I'm leaving the drip rail over the windshield and doors, but it's getting trimmed just before it makes the bend to go down the side behind the doors.
re: shave drip rail
looks great was wandering, did you grind it totally smooth or did u leave the little rigde around where the rail was. hard to explain but u know
chris
chris
- FoMoCo
re: shave drip rail
totally smooth, with sharp edge.
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- 71f100
re: shave drip rail
Now that looks trick, Excellent job FoMoCo. I have to agree with BCOOLEY
'71 F100
'69 XT Fairmont
'99 Fairlane Ghia
"May all you problems be small ones...................and squeal like hell!!!"
'69 XT Fairmont
'99 Fairlane Ghia
