are all 4wds "high boys"
Moderator: Doug Comer
- 460 crew
How wide are the F150 4x4 springs Keith?
re: are all 4wds "high boys"
ummmm....I don't know, I didn't measure them. But the next time I'm out there I will, as well as the other trucks.
- rjewkes
Am i gonna nned a set of those blocks for a 69 4x4?
fuelly.com
fuelly.com
- ICEMAN6166
Re: re: are all 4wds "high boys"
yep.stock with the factory u-bolts when i took them out in the summertime460 crew wrote:It must be so cold up there they shrunk and your tape mesure was warm Did the 3in tall block you removed have the bumpstop provision on it? And they were 2.25in wide?
.actually other than my 66 it was the first f250 i had seen with only the 3" blocks but now i will have to look at the 68 and 70 i have here too.
on the 72, i took the 60 and 3" blocks out, put in a posi 70 and the 4" blocks.
also put a 65 f350 cab and holmes 460 wrecker on the back.
http://www.fordtruk.com/forums/album_pi ... user_id=26
- averagef250
- ICEMAN6166
i was looking for the blocks the other day for just that reason.when i find them i am going look for the #.averagef250 wrote:It's always possible someone swapped under some 3" blocks. You didn't happen to read the casting numbers on the blocks did you?
I think the dentside F-150 4x4 springs are 3" wide.
i do not think they were changed ever, the u bolts were the ford ones , not aftermarket or made in a shop.
