Fender Questions
Joshpow
Fender Questions
Post by Joshpow »
Have any of you ever noticed a slight difference between the 60's fenders and the 70's fenders for these trucks? I got a fender from a 67-69 to put on my 71, and noticed that the area where the panel behind the grille lays in the top of the fender is a little smaller on it than the 71. I also noticed that the holes for the grille to mount are a little different and need to be re-drilled for my 71 grille to work. None of this is a really noticeable thign, but there does seem to be slight differences. Is this really correct or am I out of my mind?
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
1968_ONEHUN
re: Fender Questions
Post by 1968_ONEHUN »
Did you change the rad support also?If so,the newer rad supports (73-79 trucks) are a little different.The fenders are the same from the 67-72's though.As far as being out of your mind,you'd need to get professional help to find the answer to that.I'm just a Millworker sorry ! :lolprev:
1968 F-100 Custom Cab
300 6cyl 4spd
If it ain't broke,what the hell, fix it anyways !
sdranch71
Post by sdranch71 »
Ford lists the same service part number for all 67-72 front fenders:
C7TZ-16005-A RH
C7TZ-16006-A LH
Jim
mk
Post by mk »
No, Josh, you're not losing it. I discovered the same thing when inspecting some fenders I had a couple of years ago. The fenders were drilled different for 70-72 because of the change in grill design. All other mountings are the same. I love detail stuff and I've noticed lots of subtle differences in the 67-72 series interchangeable parts.
mike
68F250
Post by 68F250 »
Hi Mike :hi: and :wel: to the site!! (it's about time :D )
Glad you found the place and look forward to reading your accurate and informative posts. See ya around. :rock:
Man are we getting the experts here or what!
Barry
Joshpow
Post by Joshpow »
Man Im glad someone else has seen the differences also. I was beginning to think I was going off the deep end. Thanks for the input everyone. I know this was a sort of stupid post, but I love to pay attention to small details such as this that are often overlooked.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
