Starting Problem
re: Starting Problem
Time to see the "flywheel Dentist" soon.
- bigman78
The motor runs well the only real problem is the flywheel. Which is going to be replaced. Ive tried rocking the truck but its sitting in a rut so its kind of hard to do by myself. And one other thing, today I was working on some wiring. First I mounted a splitter with a 12 guage wire from the battery to inside the cab. I mounted this splitter to the firewall. My problem is is that I wired the stereo power to this and when I push the horn it turns the stereo off for a few seconds and then comes back on. Is this because my splitter is metal to metal on the firewall and the grounding of the horn resets it?
(my friend got a pretty good laugh out of this)
1967 F-250 4X4 Highboy, 429, D60 rear, D44 front, NP435 trans, Dana 24 T-case, PTO winch
http://profile.myspace.com/index.cfm?fu ... =136460833
http://www.fordification.com/galleries/ ... ?cat=10577
- 68F250
What's a splitter?
Barry
- bigman78
The reason I say that is because I noticed it after I screwed the splitter to the firewall. So where should I start to fix?
Its an electrical splitter. I bought it at radio shack. Its great for wiring accesories because you can just run a short wire to it and then to a switch when wiring lights and things, eleminating the need to run a wire to the battery everytime. I just ran a 12 gauge wire to the inside of the cab and hooked it to the splitter. Making the splitter a constant hot. Ill post a pic later.
actually, your problem MAY be from grounding out. I don't see a radio and horn pulling so much current it cuts the other off. I could be wrong though. Seems like a ground problem one way or the other, not a voltage deal.
- 68F250
Got it! Went to Radio Shack online and it's called a power split, glorified distribution block.
Hey they got 1.0 Farad capacitors, holy cow!
Barry
Re: re: Starting Problem
Yeah but that means radio shack is talking marketing not electricity.68F250 wrote:Got it! Went to Radio Shack online and it's called a power split, glorified distribution block.
From Napa a fuse Block that does just that
- bigman78
So I got the truck to roll down the hill and nothing. So then I got a socket and turned the engine manually with the pulley, still nothing. So now my truck sits next to the road and I cant move it. Any ideas?
- crash_552
It is manual right?? Try pull starting it. Or push starting it. I've heard that a hydrolock will sound like a bad starter/flywheel too.
Good judgment comes from experience... and a lot of that comes from bad judgment
http://www.fordification.com/galleries/ ... ?album=731
- bigman78
Yes, it is manual. Ill keep trying different things. Im supposed to be getting nearly $2000 next week and thats one thing that will get fixed.
- bigman78
One other thing, would I be able to turn the flywheel by hand if I removed the cover?
- crash_552
I dunno, I've never tried it. You did turn the motor clockwise right?? Anyhow I think you should be able to turn it although it may be difficult.
If the flywheel turns really easy, and the motor doesn't turn as easy, you probly broke the crank, or maybe the ring gear came loose from the flywheel.
- bigman78
I tried it both ways. Ill probably pull the plate off and get a look at the flywheel.
