Anyone running one? Where did you put it and hows the reception?
I've been thinking either between the headliner and the roof, under the dash, or somewhere up around the grille. Not sure if any of those are good spots.
Hidden antenna
Hidden antenna
- rjewkes
I've thought about putting an electric/motorized antenna in the original spot.
that probably means cutting out and frenching in an access pannel under the cowl side behind the pass. fender.
fuelly.com
fuelly.com
re: Hidden antenna
I bought one, but have not gotten that far on my truck yet. I hope it works well. I plan on mounting it under the dash above the glove box. Its instructions say it needs a 1/2" clearance on one side when mounted near metal.
2012 Chevrolet Silverado 2wd 4.8 ls auto
2002 Toyota Sequoia 2wd 4.7 auto
1985 GMC 3/4 ton 2wd 350 automatic
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1971 F100 2WD LWB 302 T18 3.70 9inch PS PB
1970 VW Type III squareback cut into pickup dual carbs
1967 Ford F100 LWB 352 3.03 9inch
1967 International Travellall Panel truck
1966 International Scout 800 4X4
1964 Chevrolet C10 on 1986 4X4 frame 350 700r4
1958 Chevrolet DelRay 235 3 speed
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
