Cruise Control Relay
68 F-250 has dealer installed cruise control. The relay went out few years ago. It will drain the battery if I keep it hooked up. It is made by littlefuse inc, has a number painted on it of 204912. Y'all have any idea where I can purchase one of these fine relays Dunno if pics will help.
re: Cruise Control Relay
I cant tell from the pics how many pins that relay has, but you might check NAPA, they usually have a pretty good selection of relays for about 5 bucks or so.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
