Wiper switch installed
460 crew
Post by 460 crew »
I finally broke down and spent the 50 bucks on ebay and bought a 78-79 intemittent switch and relay. Took a whole hour if that for the total install and is well worth the effort. I recommend it to all the 67-72's that ever see the rain even a little bit. Just one of those little things that makes driving an old ford a little sweeter. :wink:
flyboy2610
re: Wiper switch installed
Post by flyboy2610 »
This is one of the items on my list to do for my truck.
Any tips or tricks you learned while doing yours?
Red Green
you'd better be right.
460 crew
Post by 460 crew »
It's pretty straight forward I just took a few glances at the writeup Keith has on it and I had purchased a new air cutoff tool and a dremel.... was a good excuse to buy some tools and ease my mind about it. Just measure twice and cut once and it all falls into place. And to think I have it in there and it rained all day at work and I got off and it stopped so I didn't even get to use it. :x
wt4speed#2
Post by wt4speed#2 »
I concur definitely a sweet up grade to our era trucks, I found one out of a bronco while hunting parts for motor swap(which is currently on hold).On same day found a primo factory plastic washer bottle(still white????) and the pump for it in a truck a couple of rows over. Got intermittent wiper, personally hate wipers any way , and working washer all on same upgrade work day. Bye the bye, hooking up the ground wire is a key step!!!!
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
heep70
Post by heep70 »
Intemittent wipers is the way to go. I like the fact that you can control the time inbetween wipes. I need to find a way to do this with my Subaru :hmm: .
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
